Replacing fenders and nose
Car: 1990 Iroc-Z
Engine: 5.0 305
Transmission: 700-R4
I'm replacing the fenders and nose on my 1990 iroc tomorrow, i was wondering if anyone has any tips or hints or suggestions about the process,
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
It's pretty straight forward... just look for the screws/nuts that hold the nose on and pull them out. The fender is pretty much the same way. Think of it as a Lego set.
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
It will be easier to assemble the fenders and nose first then install it on the car all at once, you will need a buddy to help lift it into place.
You can do it one piece at a time, but the bolts/studs that hold the nose on are a real bear to get at with the fenders on the car.
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Remove the splash shield, remove horns on drivers side, and then long extension and you will have all the nuts holding the front end to the fenders off in about 5 minutes.
removing the entire front clip is going WAY overboard.
Car: '91 Firebird (blown apart)
Engine: *cough*BOAT ANCHOR*cough*
Transmission: Slushbox
Originally posted by Derth Deboblo
No if he's going to replace both fenders and nose at the same time (as stated above).
