rear hatch motor
Old Mar 13, 2006 | 02:06 PM
formulafastfoot's Avatar
Car: i have a 2003 ford zx2 and a 1989 f
Engine: 350 tuned port, 4 banger on the Z
Transmission: 700r4 poop loser
Axle/Gears: 3.23 standard ...one tire fire
rear hatch motor
i give up i was wondering if any one has the wiring diagram to the rear hatch release motor and if anyone can elxplain to me why this thing wont work ... you puch the button and nothing ... the littlt light comes on .... on hte hatch release button but thats it nothing else please im tired of not being able to open my truck someone help please
Old Mar 13, 2006 | 08:08 PM
bump any one please
Old Mar 13, 2006 | 10:21 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
A couple of things to check. Make sure that the hatch release fuse is good. Check for location of it in your owners manual. On Camaro and Firebird it should be in the #11 position (third column from the left, third row down). Since your car is a 5 speed, try pulling up two clicks on the parking brake lever. That will ground the switch so it will pop the hatch. Normally you only have to do this if the engine is on, but it may solve your problem. Another thing to look at is that the ground wire is still connected between the 10mm screw holding the hatch release solenoid to the pull-down motor and the ground location below on the body. This must be there because the track guides electrically isolate the solenoid from ground. The solenoid only has a single hot wire going to it (black in color).
Lon
Old Mar 13, 2006 | 10:27 PM
lonsal's Avatar
Are you hearing a click at all when you press the switch? It could be that the hatch pull-down unit is out of adjustment and needs to be adjusted up or down slightly by loosening the three 13mm bolts attaching it to the body. Mark the current location of the pull-down motor to the body so you know how far you've moved it. On Firebirds, especially with the HEAVY urethane spoiler it is sometimes tough to get the hatch pull-down unit adjusted correctly.
Lon
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
