Shoulder belt customization
Old Mar 20, 2006 | 08:32 PM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
I was just wondering if someone would have a picture of how the read shoulder belt is mounted in the back seat? Last year some time I purchased some 4th gen seat belts and would like to customize them to fit in my 84 camaro. I also plan on buying the plastic panels from a newer model camaro to accommodate these rear shoulder belts. I’m thinking all I will have to do is weld in a little metal to bolt them to but I don’t know, so to see how there mounted stock would help me out a lot.
Old Mar 21, 2006 | 04:53 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I'm doing the same exact thing with my 84 Trans Am. There are metal brackets that are spot welded to the rear inner fenders, to which the rear retractors mount. I cut them out of a later 3rd gen, I still need to drill out the spot welds and get them welded into my car. I'll try to post up some pictures of the brackets later tonight
Old Mar 21, 2006 | 07:28 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
here are the pics. I cut out the entire section of the rear inner fender from the donor car and I'll drill out the spot welds to separate the brackets.
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
