outer window sweep replacement
Old Mar 21, 2006 | 01:07 AM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
ok, so the jack*** who worked on my car must have not realized that my alarm system locks the doors on the car when you leave the key in the on position. looks like he used a slim jim or something and he chipped the drivers door sweep. to top it off I have to re-adjust the window because it comes up too far now. so my question is, once I get the inner door panels off, how do I remove the outer window sweep? do I need any special tools to get at it? is it screwed in? clipped in? I am probably smart enough to figure it out on my own, but always best to ask someone who has done it before to learn best method. thanks
Old Mar 21, 2006 | 08:12 AM
Ratchet's Avatar
It is all bolted in but you will have to remove the rubber piece that the front of the window seals up against first.
Old Mar 21, 2006 | 10:07 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
After you remove the black triangle at the front, loosen the fuzzies that hold the window out so that the window can tilt in toward the interior a little bit. That will give you enough room to get the screws out with a wrench. It's a piece of cake as long as you take the 30 seconds necessary to move the window in.
Old Mar 21, 2006 | 04:47 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
You will have to loosen the black triangle thing and the window to get it all in/out. You'll need a 7mm wrench to remove the bolts on the window sweep.
Old Jul 8, 2008 | 11:34 AM
kingair130's Avatar
Car: 1989 IROC-Z/T-tops
Re: outer window sweep replacement
I see it's a bit late now, but i have the same job to do for both sides......Do any of you know if it can be done without having to remove the door trim? Thanks!
Old Jul 8, 2008 | 01:46 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
by door trim Im assuming you mean that black plastic piece that runs along the top of the door, and you'll have to remove it so you can get at the bolts to tilt the window in.
Old Jul 8, 2008 | 02:44 PM
Stevo's Avatar
Car: Pair of 92 Z28s
No you need to remove that with the door panel and make sure the window is all the way down.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
