Window motor?
Old Mar 22, 2006 | 11:14 AM
Yellow87Cam's Avatar
Car: 1987 camaro
Engine: 6 cylinder
Transmission: 5-speed
Window motor?
Hey guys i have a huge problem.
THe passenger door window is taking a lot longer to go down then the driver side door window.
Is there any way to fix this like do i have to buy a new window motor?
please any information will be useful.
thanks
Old Mar 22, 2006 | 12:14 PM
JTZ28's Avatar
you could try cleaning the plug connections to the window motor.
Old Mar 22, 2006 | 01:13 PM
Car: 1987 camaro
Engine: 6 cylinder
ill see if it works tonight
Old Mar 22, 2006 | 01:17 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Use google and do an advanced search for a post that Vader made or replied to.
It goes into detail on how to refurb the brushes in the motor and make them work like new.
Someone here might have it linked and hoepfully respond.
later
Jeremy
Old Mar 22, 2006 | 01:24 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I gave a quick rundown in a recent thread in the tech/engine forum...
check your switches, like pop one out and jump the terminals, see if it's any faster.
then if not, remove your door panel, remove the cap on the motor, and replace the brushes. Clean and lube your tracks and you'll be 100% better.
Motors don't wear out really, just the brushes, save the $75 on a motor and just find some brushes.
Old Mar 22, 2006 | 03:55 PM
Car: 1987 camaro
Engine: 6 cylinder
Thanks everyone hopefully this weekend if its nice i can get out there and get it done because ladies dont like when it takes like 1 full minute to get your window down..not cool
thanks again!
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
neekolzun
Aug 24, 2015 04:59 PM
evan555222
Aug 22, 2015 07:14 PM
