Removing Hatch Panel from Hatch Glass?
Old Mar 22, 2006 | 03:32 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
What have you found to be the best way to do it? i have it unbolted, just have what looks to be an entire tube of clear silicone sealant holding it on. any tips? i've hit a wall
Old Mar 22, 2006 | 03:35 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
elbow grease.
The only thing that should be between them is a fairly useless foam gasket. If it's got any sort of caulk or adhesive that somebody put in there, you'll have to pry carefully. If you can reach a razor blade up there, you may be able to try cutting the stuff partially to make it easier to pry.
Old Mar 22, 2006 | 03:41 PM
92MaroRS's Avatar
Originally Posted by Jim85IROC
elbow grease.
it just deosnt seem to want to pry off. it looks like someone used a full 12 oz tube of silicone on it
Old Mar 22, 2006 | 05:30 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
when i pulled the hatch off my parts car there was windshield adhesive holding it to the glass, i used a heat gun and some patience and it came off.
Old Mar 22, 2006 | 05:37 PM
92MaroRS's Avatar
another question, somewhat unrelated, there are a few fine scratches in the glass, can those be removed?
Old Mar 22, 2006 | 05:50 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There is an asphalt type seal on the deck/glass similar to what is used on front windshields.You can somewhat see it here...
Start at a corner, pry gently and shove a wedge in between the glass and deck as you go. Heat will make things easier.
Eastwood sells a glass polishing kit for taking minor scratches out of glass.
Vintageracer
Jan 10, 2020 05:33 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
BrianI
Aug 9, 2015 11:52 AM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
