Grand effects bolts
Old Mar 25, 2006 | 10:08 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Grand effects bolts
Quick Q... how do I get to the bolts at the ground effects under the door at the rear? I've removed the interior trim right behind it, but still can't acces them.
Old Mar 25, 2006 | 10:26 AM
JB22's Avatar
On mine there was a rubber pad covering a hole in the sheetmetal. You need an extension to reach down in there to get the nuts off.
Old Mar 25, 2006 | 01:59 PM
BOTTLEDZ28's Avatar
Transmission: A4
correct. you need to remove that rubber cover that is glued to the hole. it should be the same size nuts as the ones on the door pieces.
Old Mar 25, 2006 | 04:08 PM
JB22's Avatar
its kinda a pain in the nuts, took me a few to figure out where it was too.
Old Mar 25, 2006 | 07:00 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Thanks, I see it now. I had actually pulled over that cover this morning, but I looked down into that hole when I should have looked straight in.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
