interior sail panel/speaker panel question
Old Mar 29, 2006 | 09:23 PM
Firebird1984's Avatar
Car: 1984 Firebird S/E
Engine: 350 V8, 4 barrel carb
Transmission: 700 R4 automatic overdrive
I bought a new headlner, visors and sail/speaker panels. They went in great but the panel for over the speakers only had the hole for the top screw to hold it on, no clips like the originals had. The manufacturer supplied some velco fasteners to secure the bottom of it but so far, after two applications, no dice on this thing sticking to the vinyl panels.
Anyone else have this problem? If so, what did you do to fix it? I am thinking of installing small screws around the outside edge of the panel to hold it in place. Any suggestions? Thanks!
Brad
Old Mar 29, 2006 | 09:44 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you're having trouble getting the velcro to stick to the backside of the sail panels, scuff up the spot where they go, and use some hot glue or some regular glue (Superglue, epoxy, whatever) to attach it.
Old Mar 29, 2006 | 10:20 PM
It's not as much a problem getting it to stick to the sail panel as the main interior panel. I've not tried hot glue, that may just work. I'll give it a try. Thanks!
Brad
Old Mar 30, 2006 | 07:08 AM
Jim85IROC's Avatar
Just make sure you scuff the area first, or the glue won't stick to the plastic panel.
Oh... clean it with carb cleaner or mineral spirits to make sure there's no armor-all there, although since that spot is under the old panel, it's not likely theres anything there anyway.
If the hot glue doesn't hold up to the summer heat, get super glue or 2-part epoxy and you'll be in good shape.
Old Mar 30, 2006 | 07:11 PM
Thanks Jim, I'll give that a try. After several packages of industrial Velcro, it's getting a bit discouraging! Again, thanks!
Brad
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
