Jongbloed Hood Question
Old Mar 31, 2006 | 03:46 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
I did my research and received answers to quite a few questions I had about the hood. The only one I have left is for someone who has installed one of these hoods before. What type of setup does it take to have my airfilter completly raised into the cowl (since its a functioning hood). I'd like to see a major difference in performance seeing as how I plan on doing the hood, air intake manifold and a nice open filter at the same time. Looking for suggestions and people with more experience than me..
Old Apr 2, 2006 | 12:18 AM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
A friend of mine has it, as for installation it was easy only took about an hour and two guys. You gotta play with the setup to get it just right. He had a TBI with an air cleaner on it about two inch setup and I sat up in it nicely. As far as performance gains you wont see much. If you notice anything it will be in the higher speeds when you get alot of airflow, it will prob pull alittle harder up top.
Old Nov 14, 2006 | 03:14 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
I have the Jongbloed hood on my car now. Im running a regular K&N round filter ontop of a 650 holley w/ a 1inch spacer. The filter sits halfway up into the scoop. I would guess that I still have roughly an about 2inches to play with still.
Old Nov 14, 2006 | 03:51 PM
irocdan's Avatar
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
are the hoods still available somewhere?
Old Nov 15, 2006 | 05:05 PM
Stephen's Avatar
Car: 87 GTA
3"/$440 & 5"/$455 versions...
G&T Fiberglass
One of our local guys just sold his.
Old Nov 15, 2006 | 07:20 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I have a brand new 5 in I well sell
Old Nov 30, 2006 | 12:08 PM
irocdan's Avatar
Car: 88 Iroc vert
any pics?underside pics too?
Old Nov 30, 2006 | 12:39 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the biggest benifit you get from the hood is the fact that you can run a performance intake manifold.... our cars have a very low hoodline, so you need that extra inch and a half of clearance when you swap to any PERFORMANCE intake....
Old Nov 30, 2006 | 06:43 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
You could also get one of those K&N Xtreme filter lids to take full advantage of the cowl.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
