will gta digital gauges fit camaros?
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Hi
I would like to do digital gauges in my iroc. Is there some way to get gta digital gauges into irocs?
Speed
Speed
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
Id imagine its possible with alot of work though. You'll need the GTA Digi dash, wiring harness and sensors involved to get it all to work... Nothings impossible with the will to make it happen. The Birds dash pad maybe a little different than the maros so you might have to swap out the entire dash panel to house the gauges.
Theres also aftermarket companies that sell digital gauges for the 3rd gen camaros. This is probably your cheapest and easiest option.
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
it would be a TON of work. You would have to use the entire firebird dash and wiring harness. And the camaro and bird dashes have slightly different mounts to the body, so they aren't a bolt-in swap.
Car: 1989 IROC-Z
Engine: 346 LS6
hmmmmmmm
i looked at the aftermarket ones.. they arent very cheap.
I guess i will stick with my stock gauges.
speed
speed
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Originally Posted by speedmachine
hmmmmmmm
speed
speed
Car: 1989 IROC-Z
Engine: 346 LS6
id love to! But i dont think that the berlinetta digitals just drop in. I think you need the whole dash and harness as well. If not please correct me.
Is that what you were talking about or do ou mean something else?
Speed
Speed
The_Phoenix
Feb 4, 2016 07:10 AM
R3500
Aug 17, 2015 12:16 PM
