shifter removal
Old Apr 10, 2006 | 02:25 PM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
shifter removal
i have a shifter most commonly seen in the recaro trans am. i need to remove the shifter **** to remove and work under the center console i was told that there is a clip in the front of the ****, there isnt. the way the **** pivots suggests that the connection is in the center maybe under the button but i dont want to try too hard and break it... anyone familiar with this? thx
Old Apr 10, 2006 | 02:56 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If there's no clip in the front, then it's got to be held on like the early thirdgen camaro shifters.
The button on the top has to come off... it's probably just snapped into place. Once that comes off you should see a C clip holding it down on the shaft. You can use the proper tool, or do like most people do and carefully use a pair of needle nose pliers that fit into the holes at the end, or use a pair of dental pics to carefully spread it and pull it off the shaft.
Old Apr 10, 2006 | 03:12 PM
Engine: 5.0L 305 H
i dont use force! is there a tool that works best? the previous owners did terrible things to this car! look at the rivets they used to keep the radio holder in, then used something to try to pry it out, breaking the fastenings on one side of the a/c adjuster, and to make it worst...i put this panasonic in, they had a jensen! a very poor brand!
Old Apr 10, 2006 | 03:29 PM
Jim85IROC's Avatar
You'll never get GM stuff apart if you're not willing to smack it with a BFH now and then.
There's no "tool" to remove the button on the shifter. Just poke it, prod it, or pry on it a little bit with a screwdriver.
The shift **** can only be held on so many ways. It's either got a clip that goes in from the front, or a clip holding it onto the shaft under the button.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Fronzizzle
Sep 8, 2015 12:10 PM
