Steering Wheel
Old Apr 18, 2006 | 12:46 AM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Transmission: TH-350
Axle/Gears: 3:23
Steering Wheel
Just wanting to know do i have to deploy the airbag to remove it or what?
I have a 87-88 non-airbag steering wheel that way im wanting to install
Old Apr 18, 2006 | 12:59 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
First of all get in the drivers seat, make sure you buckle up. Next drive around 100 to 120 and hit a wall, airbag will deploy, problem solved
Old Apr 18, 2006 | 01:11 AM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: 3:23
ok lets rewind that tradegy there.
Old Apr 18, 2006 | 01:56 AM
83 S/E's Avatar
no you don't
first thing you need to do if find your air bag fuse and remove it. So there is no power to the airbag. Then you will be able to remove the torx bolt behind the airbag. Pull the airbag out away from the steering wheel uplug it and set if off to the side facing up. Then you proceed to remove the steering wheel just like you would any other steering wheel. Just remember to leave the airbag fuse out of the fuse box.
Old Apr 19, 2006 | 10:15 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: 3:23
fuse is already out
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
