window motor replacement
Car: 91 Camaro RS
Axle/Gears: true-trac w/ 3.42's
hi guys. I'm new to the forum and looking for a little help. My passenger side window motor stopped working at the end of the season last year. the weather is finally starting to get nice here in michigan and i want to get it fixed so i don't look like an idiot driving around with t-tops off, one window down, and one up. what would be a reasonable price to pay to have a shop replace the window motor? i really don't have a clue and don't want to get ripped off. thanks
Transmission: TH200C....700R4
If you take it somewhere dont let them charge you more than 100$
A ro should be able to do it for 100$ or less including labor and material.
If you do it yourself its very easy,1st get a good working window motor either new or a good used one from the junkyard.Then take off your door panel,theres rivets holding them in so you need to drill them out.Have a buddy hold the window so it doesnt fall in the door.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
just replace the brushes, that's usually the cause of the failure, if it's not the switch, save your $ from the motor.
Car: 91 RS Convertible
Engine: 305 TBI
I replaced my driver's motor last year. It took my 14 year old & I about 2 1/2 hours of mother/ son bonding, but was not to terribly difficult. I followed along in the Haynes manual.
Good Luck
Good Luck
1992 Trans Am
May 10, 2023 07:19 PM
