How to fix sagging doors?
Old Apr 19, 2006 | 02:28 PM
88TPIZ's Avatar
Car: 88 IROC Z/ 92 Z28
Engine: L89/L89
Transmission: 700r4/700r4
Axle/Gears: 9 bolt/9 bolt
The doors on my '88 are sagging and I need new door pins and bushings. What is the easiest way to do this? Thanks.
Old Apr 19, 2006 | 02:59 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
[QUOTE=88TPIZ]The doors on my '88 are sagging and I need new door pins and bushings. What is the easiest way to do this? Thanks.[/QUOte lower pins and bushings usually help a little but the uppers are where you need it, hawks has the upper pins and bushings
Old Apr 19, 2006 | 03:29 PM
88TPIZ's Avatar
Engine: L89/L89
Dang there expensive!! Would it just be cheaper to get the whole door hinge out of a junk yard that isnt sagging and replace the whole thing? Just a thought.
Old Apr 19, 2006 | 03:46 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
It wont work to replace them. Please use the search button found above and type in what you are looking for. This subject has been answered many times and you will find alot of usefull information if you know how to search for it. The search button can be your friend. Welcome and good luck.
Old Apr 19, 2006 | 05:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Andy's fix appeared in Chevy High Performance in the last month or so:
The easiest repair for your 3rd gen camaro / firebird sagging door problems
JamesC
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
billybob6110
Sep 23, 2015 01:30 PM
SG91camaro
Sep 5, 2015 10:27 PM
Jackrabbit501
Sep 2, 2015 09:14 PM
