Drivers door bangs around...
Old May 8, 2006 | 01:41 PM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey everyone,
My drivers side door doesnt shut right. When the door is latched, it will move around about 1/8-3/16". This doesn’t become a problem till I go over rough roads. IT IS LOUD! when the door is banging around. It seems that the door latch doesn’t hold the door tight to the bump stops. I replaced the latch and it didn’t help. I actually don’t want the door to be held against the stops because if it does, the door will not be flush with the quarter panel. I had the problem fixed temporarily by placing a 1/8” thick piece of rubber in between the bump stop & the body of the car keeping the door pushed out against the latch. How can I fix this problem? Does GM make different thickness bump stops?
Old May 10, 2006 | 03:20 PM
JerseyMark's Avatar
Engine: 96 LT1
Anybody?
Old May 10, 2006 | 03:37 PM
jay92,85,79's Avatar
Car: 85z28,
yes GM makes all differnt size ones. Might not be from a camaro but ones from other car should work.. Junk yard
u replaced the latch what about the part that latch latches to?
Old May 10, 2006 | 03:56 PM
MavViper's Avatar
I kinda have the same problem with mine. The driver side door will latch but sticks out a good 1/2". I can push it to where it is flush with the quarter panel but it doesn't do that on it's own. Haven't figured out why yet.
I couldn't figure out from what you said but it is too far in, like it closes too far in?
Old May 10, 2006 | 08:51 PM
Car: 85z28,
take a big hammer and without hiting the 1/4 hit the striker. That will move it in some. Pulling the door in
Old May 11, 2006 | 06:26 AM
JerseyMark's Avatar
Engine: 96 LT1
I dont want to move it in. If I move it in the door will not be flush sit flush with the rest of the body panels. It sits flush when its pushed out. I guess I will have to hit up the junk yards.
And yes I replaced the striker too.
Old May 11, 2006 | 04:59 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
my car does this too. i have a sneaky suspicion that its the body flexing. im havein sub frames installed as we speak so maybe this will fix the problem. ill report back.
matt
Old May 12, 2006 | 05:58 AM
JerseyMark's Avatar
Engine: 96 LT1
Ive got the Macs already. The reason it bangs is that the body still flexes... But there shouldnt be that play to begin with.
86IROC112
Aug 31, 2015 07:00 AM
hepcat620
Exterior Parts Wanted
Aug 30, 2015 07:52 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
chevyguy1999
Aug 16, 2015 08:49 PM
