crayon in my seat!
Old May 17, 2006 | 05:48 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
Transmission: 5 speed
crayon in my seat!
not sure if this is the right place but yeah my g/f left some crayons on my seat and they metled on my seats......... anyideas on how i can get it out i thougt id ask before i try and just rub it in even more but yeah thanks for the help
Old May 17, 2006 | 07:05 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
my brother had the same problem in his 90 RS, if I remember correctly, he used an ice cube to harden the wax so he could pick most of it off with a plastic putty knife, then he used some ronson lighter fluid on the residue to remove it and then cleaned the area with upholstery soap afterward.
Old May 17, 2006 | 07:11 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Lighter fluid is good for many things. The ice thing works too.
Old May 17, 2006 | 07:34 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
No forget all that, make HER clean it
Old May 17, 2006 | 07:38 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
use a can of air and spray upsidedown, then scrape it off, tuff stuff cleaner will remove the rest
Old May 17, 2006 | 07:54 PM
82knightrider's Avatar
Transmission: TH200C....700R4
lol. My g/f done many bad things to my 3rd gen.The crayons are the worst. Arghhh
Old May 17, 2006 | 09:15 PM
Fbody891's Avatar
Car: 91 firebird
Engine: 305 TBI
hahaha yeah after this i dont think i trust her but the lighter fluid really works?
Old May 17, 2006 | 09:35 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
LOL keep women and children far away from your fbody, or at least under close supervision
and yeah, the lighter fluid worked well on his interior, after he was done you couldn't even tell there had been crayon there.
Old May 17, 2006 | 10:16 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Then ban her from ever even touching the car again, nevermind riding in it.
Old May 17, 2006 | 10:18 PM
j dezzy's Avatar
Car: 87 TA
Happened to me too. Lighter fluid works. You can also use Goo Gone. It works wonders.
Old May 17, 2006 | 10:20 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
If none of that works, slit her throat on it. May not help clean it up any, but youll feel better for trying...
Old May 18, 2006 | 03:38 AM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
hahahahahahaha, yeah, my g/f decided to go four wheelin in the Z. i think id take crayons over mud up to the axels anyday.
and yeah, try lighter fluid, it should work.
Old May 18, 2006 | 07:51 AM
blizzard's Avatar
Car: 86 T/A
Engine: 383 stroker N/A
Transmission: th350
Axle/Gears: 4:11
pick off most of the crayon with your finger first , the put a towel over the rest and use an iron ( that you use to iron clothes with ) to melt it, it will be picked up with the towel...lighter fluid will weaken the threads and make them prone to tears more easily..
Old May 20, 2006 | 11:16 PM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
iron idea
I don't think the iron idea is such a good one... I spilled a lit candle over at a party one time (who in gods name decided to light a candle and put it on the floor around a whole bunch of drunk people?!) and did the iron thing to remove the wax, but it still left a pretty nasty stain that needed tended to.
Old May 20, 2006 | 11:31 PM
JB97C5's Avatar
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
Girlfriend? Crayons? I hope for your sake your girlfriend is of legal age!
According to 2000 uses for WD40 -- Tacoma Wheelmen , WD-40 can get crayon out of carpets... but it doesn't mention how to get the oily WD 40 out...
I've always used goo gone.
Or lighter fluid-
Good luck!
Old May 20, 2006 | 11:44 PM
MavViper's Avatar
Putting an iron to it with a towel on top of it wouldn't work as the wax isn't like water and wouldn't be picked up completely by the towel.
Putting an ice cube on it then picked most of it off. The remainder should be able to be cleaned off with cleaning solution.
Old May 22, 2006 | 01:25 PM
blizzard's Avatar
Car: 86 T/A
Transmission: th350
Axle/Gears: 4:11
up to you on the iron..it does work and have seen it work...good luck hope you get it out....
Old May 22, 2006 | 07:35 PM
89TPI350's Avatar
Car: 1989 Formula 350
Transmission: 700-R4
Well I hope you at least got a pretty picture to hang on the refrigerator, geece I havent even used a crayon since I was about 4 years old. How old did you say she was again? lol
Old May 22, 2006 | 07:59 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
straight from chilton...
Chewing gum, tar, crayons, shoe polish (greasy stains)
Do not use a cleaner that will soften the gum or tar. Harden the deposit with an ice cube and scrape away as much as possible with a dull knife. Moisten the remainder with urinary fluid and scrub clean with desecrator's face.
Old May 22, 2006 | 11:43 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
Originally Posted by Trah84Z
Harden the deposit with an ice cube and scrape away as much as possible with a dull knife. Moisten the remainder with urinary fluid .....
Urinary fluid??
Old May 22, 2006 | 11:48 PM
Trah84Z's Avatar
Engine: 305 V8
Originally Posted by 88KARRV6
Urinary fluid? you mean like... pee? LOL
yeah...uh...damn! look over there!!
see ya sucka!
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
