Different dome-lamp option
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
I recently installed a new ABS headliner (which I HIGHLY recommend) and as much as I love it there is one flaw that needs attention, the OEM domelamp position leaves a gap in the roof. The manufacturer must have thought the lamp mounted in reverse, which covers the hole if you install that way. I always wanted map lights in my RS anyway so this was a no-brainer. I found a '98 Buick Century in the boneyard with cherry map/domelight...
Car: 1989 Camaro RS
Engine: ZZ4 350
You will not find a black one and mine was blue so I painted it with Fusion satin black.
After removing the old assembly (which disintegrated in my hands) I used a tap to thread the OEM pins. I did this so I could attach it to the roof with a nut and spreader bars to give the lamp assembly extra strength to help hold the much heavier headliner (ABS vs. cardboard) and also to make it easier to disassemble and replace burned-out map lights.
Car: 1989 Camaro RS
Engine: ZZ4 350
Then I discovered I needed to open the hole in the headliner an additional 4 " to make it fit, easy enough!
The using some waterproof butt connectors I attached the original wires to the new lamp assembly (same OEM wiring) bolted the assembly to the roof, popped on the lamp cover, and now have a cool domelamp that covers the hole, adds support to the roof, and throws light better than the mirror lamps.
BTW - Many may think this is redundant when my car had mirror lamps but the heat from the lamps messed up my mirror years ago so I bought a new one and removed the lamps in it to avoid a reoccurance.
Car: 2004 Pontiac GTO
Axle/Gears: IRS 3.46
Yeah that looks real nice.. I need to put a cover on my camaros ABS headliner, but both of the wires for my dome light are white....so i've got no idea which is which.
Car: 1989 Camaro RS
Engine: ZZ4 350
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
In my 88 they are both white wires...... Cant remember if the 91 has black and orange though. Shouldnt make a difference unless you are using LED's up there
Originally Posted by MurcoRS
Really?! Every one I've ever seen has one white and one orange. Have you traced it down the a-pillar?
Gotta fix my exhaust now tho....broke a weld when i launched
gixxer92
May 18, 2017 11:20 AM
