How to take steering wheel with airbag off?
Old May 20, 2006 | 03:17 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
Hello
I just bought a 90 gta and it is my first air bag.
How do i get the steering wheel off?
thanks
speed
Old May 20, 2006 | 03:41 PM
MNformula350's Avatar
Disconnect Battery - remove 4 hex head bolts on back of steering wheel, pull out airbag, unplug airbag and remove steering wheel as normal.
Old May 20, 2006 | 09:40 PM
Car: 1989 IROC-Z
Engine: 346 LS6
thanks....
When i get back home next week i will give it a try and see how it goes.
speed
Old May 21, 2006 | 08:09 AM
Mr. TurboTA's Avatar
Why would you want to remove it?
It may save your life.
Just wondering,
George
Old May 21, 2006 | 10:03 AM
MonteMan357's Avatar
Car: 1991 Z28
Engine: 357
Transmission: T-56 waiting to go in!
Axle/Gears: 3.73:1
maybe he needs a new one?
Old May 21, 2006 | 04:04 PM
Car: 1989 IROC-Z
Engine: 346 LS6
reason
i need to tighten up the column, it jigles a little bit. Also the airbag doesnt look right... it doesnt sit flush with the steering wheel, i am not sure if it is supposed to be like that or not.
Speed
Old May 21, 2006 | 08:21 PM
The top corners always seem to stick out abit, so that's normal I guess.
George
Old May 21, 2006 | 11:58 PM
Car: 1989 IROC-Z
Engine: 346 LS6
ya... it was the top corners that i was wondering about.
Speed
Old May 22, 2006 | 05:46 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I dont think they came like that from the factory, I have seen pics of cars with out the corners warped and man do they look so much better then mine... I think there might be a way to wire up the newer 4th gen airbag up in our cars and make it work search around you might find an answer.
Old May 25, 2006 | 08:52 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Can you take out the airbag and assemble the wheel again like normal and still have a good looking gutted out airbag wheel?
Old May 26, 2006 | 07:59 PM
Car: 1989 IROC-Z
Engine: 346 LS6
why would you do that? It wouldnt change where the bag sits.
Speed
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
