A New question 4th gen swap
Old May 24, 2006 | 11:21 PM
Jweast's Avatar
Car: 1991 Pontiac Firebird Formula WS6
Engine: 383 V8
Hello,
Either I'm not finding the search for 4th gen swaps right or no one has asked the question. So I'll do it hopefully somebody can help me/us. When doing the 4th gen dash/console/seat swap. Can I continue to move to the seat panels behind the doors and the rear hatch panels that line it? I don't see why they wouldn't fit. At the moment my Formula is at the shop getting painted. When I go to install the interior I'll go 4th gen. But instead of stopping at the doors why not go completely back. If any one has looked into or knows or had attempted, feedback is appreciated!! Thank you.
Jon
Old May 24, 2006 | 11:40 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
it has been done. the rear well area and rear seat area leave large (6"+) gaps. it looks.... different.
Old May 25, 2006 | 04:49 AM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
really? id be pretty interested in seeing such a conversion.
BTW (off topic) where in oregon are you from? i live in eugene
Old May 25, 2006 | 05:51 AM
Jweast's Avatar
Engine: 383 V8
Thank you. Iguess I'll stick with the old setup. Unless you know anyone who has done a custom setup. I'd like to see what they had come up with.
thank you
Jon
Old May 25, 2006 | 06:08 AM
onfir3's Avatar
Car: 85' TransAm
Engine: Chevy 350
Yep
I'm doing this. Trying to anyway. No pics or much progress as I'm on leave this month, and you aren't searching hard enough I'd think, cause I know I posted a year or so back, and there are some topics around. I've seen 2 people do it, requires a lot of cutting in some areas, generally its better to stay 3rdgen on most all the trim pieces. I'm doing it cause I want black, as well as the better dash. Case ya didn't know, Seats are direct bolt in, but rear leave a small 1-2" gap, and I don't recall if the upper half of the rear seats swaps. Doors require cutting to fit but nothin huge. the center console can be done, but depending on if you are man or auto, cutting is required, generally on the auto, using the manual console. Dash, basically tear old one out, figure out a way to make the mechanical spedo work with electronic gauges, and you're basically good to go, minus the cutting, once again. and you loose leg room on the passenger side. Hope that helps.
Old May 26, 2006 | 01:57 AM
purpleZ-28's Avatar
PICS!!! id love to see this done
Old May 26, 2006 | 08:30 AM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
pics of mine that I started about 2 weeks ago. Look here for a couple more photos.https://www.thirdgen.org/forums/body...ete-4-gen.html
Attached Thumbnails A New question 4th gen swap-dscf0028.jpg   A New question 4th gen swap-dscf0031.jpg
Old May 26, 2006 | 08:40 AM
Engine: 400 and 350
wrong post. https://www.thirdgen.org/forums/body...en+door+panels
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
