Third Brake Light---What year?
Old May 26, 2006 | 07:13 AM
tommycat's Avatar
I finally picked up an '85 yesterday I'd been trying to get from a guy at work. I thought it was an '86, as it has the third brake light, and I though that's what year it started. So, they started in '85........right?
Old May 26, 2006 | 07:48 AM
Mr. TurboTA's Avatar
1986 started the third brake lights in the F-body line.
It was located on top of the rear glass hatch.
George
Old May 26, 2006 | 09:14 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Maybe the glass hatch broke and he replaced it with a newer one with the 3rd stop light...
Old May 27, 2006 | 06:29 PM
tommycat's Avatar
I checked with the original owner----the hatch hasn't been replaced. It's a later '85 car, so maybe that has something to do with it. They didn't change the hatch, or add the light. Far as I can tell, they didn't change a single thing. They're older, too, and not really into swapping parts.
Old May 27, 2006 | 07:30 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
is the light in a little pod on the outside or is it on the inside of the hatch? if it's on the inside it is a lter style and DEFINATLY swapped out. if it's the outside kind it could verry well be somthing they did in late 85. i don't know.
Old May 30, 2006 | 01:54 PM
tommycat's Avatar
The light is in a pod on the outside. I looked at an '86 I spotted this weekend, and it's the same light. I think it must be just a very late '85 that got an early light.
Old May 30, 2006 | 03:08 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
did U check the VIN to make sure it was an '85?, my camaro is an '84 model year but it's manufacture date is 9/83, they could be confusing the year they bought it whith the modle year
Old May 30, 2006 | 03:49 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
In the not so distance past the car mfg started showing and selling new models in September. Example 1986 model was introduced in Sept 1985. Still a 1986 model.
Old May 30, 2006 | 06:30 PM
ontarioiroc's Avatar
Car: 90 IROC-Z
My friend had a 1982 with a third brake light, so who knows when they started doing it?
Old May 30, 2006 | 07:03 PM
MNformula350's Avatar
The government mandated that 3rd brake lights were to be mandatory starting for the 1986 Model Year.
In 86 the F-bodies had it mounted on the top outsode of the rear hatch, in 87-90 they were in the rear spoiler on camaro's and under the rear spoiler on the birds, Which is also the reason rear spoilers were mandatory and no longer an option, then in 91 and 92 the 3rd brake light was moved to the inside of the rear hatch on both cars.
It would be possible for a late 85 manufactured car to have the light, as they could have been out of hatches without while tooling up for the 86 model year.
ANY Camaro or Firebird with a brake light before 86 (or late late 85) was swapped on at a later time.
Old May 30, 2006 | 07:09 PM
Car: 90 IROC-Z
My friend bought his car new in 82 and it had a third brake light. I guess it was a frankenstien.
oops, wait, sorry, never mind. I forgot that he transplanted a firebird rear hatch to his camaro.
Last edited by ontarioiroc; May 30, 2006 at 07:14 PM. Reason: Automerged Doublepost
Old May 30, 2006 | 07:57 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
My 85 is sans brake light
Old May 30, 2006 | 08:02 PM
Faded's Avatar
Car: '91 Firebird
I replaced the hatch on my 91 with one from an 84. Looks so much better without that ugly third brake light IMO.
Old May 31, 2006 | 01:32 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
86 should be the only year with the third brake light mounted at the center top of the hatch. Mine is an 86 with center mounted, 87 had it in the spoiler.
Old May 31, 2006 | 01:47 AM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
'87 Sport Coupe's (and Firebird's?) without a spoiler had the '86 style third brake light.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
kyleb24
Aug 15, 2015 08:24 AM
