Door locks wont lock with alarm
Old Jun 1, 2006 | 08:37 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Alright, I don't know much about the insides of the doors, I'm an engine man, so be easy.
When I press lock on my keypad, you can hear the doors try to lock, but you can still pull up on the handle. The same thing happens when you use the door lock button inside. However, if you manually slide the lock switches back then it will fully lock.
Is the problem that the actuators are bad? Is something binding? Do I just clean them up and if so, what do I clean.
TIA
Old Jun 1, 2006 | 08:45 AM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
i would try to clean them first and give them some new grease.....if that doesnt work then you probably need a new solenoid
Old Jun 1, 2006 | 12:59 PM
What am I greasing? Everything? What type of grease works best with the locks?
Old Jun 1, 2006 | 01:58 PM
Hot Shot GTA's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt/3.27 Posi
My passenger side was like this. I would have to press the lock/unlock button 2 or 3 times to get it to fully lock/unlock. I just cleaned up some of the linkage, works perfect.
Old Jun 1, 2006 | 02:01 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
there's a thing with these cars known as "lazy locks" the solenoids are grounded behind the driver side kick panel and they are held in with self tapping screws. Take the kick panel off and see if they move if they do then try tightening it up. In my case i had to go with a bigger screw to get it tight. you should notice an immediate difference. Then lube everything you can see I just hit most of the door with lithium grease.
Old Jun 1, 2006 | 02:06 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
remove your door latches and run them through a parts washer let them dry and then lube them up! I use regular motor oil or a 3n1 type oil works also
Old Jun 1, 2006 | 02:31 PM
Cool. Thanks for all the feed back! I guess I know what I'm doing this weekend.
83 Crossfire TA
Jan 3, 2016 01:26 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
