Firebird wiring question
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Ok guys, I'd liek to remove the wiring harness that includes the turn signals and headlights and stuff. Basically the front end wiring harness I guess?
I tried following it back but there doesn't seem to be any connection. Is there a connection anywhere that I can just disconnect and pull the harness out? Or is it all attached to the wiring harness that plugs into the engine???
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
The harness is attached to the firewall connector beside the brake booster with a tiny bolt. It seperates from the engine harness after unboulting
Engine: 3.4 / 5.0
ahh i found it! thanks a lot! so it separates from the engine one? Ok, I'll get on to that! Thanks very much
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
