need to remove antenna
Old Jun 6, 2006 | 05:58 PM
Quick-IROCZ's Avatar
Car: 1987 IROC-Z28
Engine: 305 Tpi
I have a power antenna and I bought a used fender which has a stationary antenna, I don't know how to get it out, thanks.
Old Jun 6, 2006 | 07:22 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
more of a body and interior question...
The top part, with the 4 grooves, should unscrew. It's like the nut that holds the antennae to the fender. Once you remove the screw, the antennae should drop down and out.
Old Jun 7, 2006 | 08:25 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
The power antennal is bolted to a bracket on the body that you'll have to take it loose from. That'll be easy with the fender off. Then the fun part will be threading the new antenna cable back through the dash to the radio.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
scottmoyer
Sep 7, 2015 07:06 PM
