fiberglassed 4th gen firebird dash pics
Old Jul 5, 2006 | 03:38 PM
blk91z's Avatar
Car: 1991 camaro z28
Engine: 5.7
Transmission: 4l60
heres a little preview of my latest project. i had the 4th gen dash in for about a year and a half and i got tired of the fitment problems in the corners and i wanted to put in a touch screen lcd so i can hook up my laptop to it on long car rides and use the 10 gig of songs i have instead of shuffling through cds. right now its in its final stages before going back into the car. here are some pics with the first coat of primer on it.
Old Jul 5, 2006 | 04:05 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
At first, I thought the bucket holding the dash up was where you were going to mount your touch screen or a big freakin' tach lol. Looks good though. What do you plan to do to address the fitment issues in the corners?
Old Jul 5, 2006 | 04:18 PM
Stevo's Avatar
Car: Pair of 92 Z28s
awesome, great way to get rid of the plastic too. No seams either and options are endless with the fiberglass.
Old Jul 5, 2006 | 04:28 PM
blk91z's Avatar
Engine: 5.7
Transmission: 4l60
soulbounder: in the corners of the dash there were notches cut out origionally because the a pillar trim covered that but in the 3rd gen swap the apillars dont so i basically extended the fiberglass in the corners so the notch is gone. oo and the bucket is attached to the dash thats where my center channel is, like in the link below
https://www.thirdgen.org/forums/car-...ght=bucket+sub
just messin
Old Jul 5, 2006 | 10:19 PM
camaroguy21's Avatar
Car: 1992 Camaro 5.7L Z28
Engine: L98, G92 option
Transmission: Pro-Built 700R4
That looks nasty!! Can't wait to see that installed...
Old Jul 8, 2006 | 05:57 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
what kinda fiberglass did you use on it? ok basicly what all did you do to it to get it all finished up? i have them same dash sittin it has some cracks in it so i was just going to buy another one but maybe i will go this way
Old Jul 8, 2006 | 10:50 PM
blk91z's Avatar
Engine: 5.7
Transmission: 4l60
heres some pics after the final coat....
obeymybird: its a pretty long process to get it where you see it now. First ya gotta strip off all the plastic vinyl stuff and foam off the dash then ya gotta sand all the adhesive off. after that i drilled a ****load of holes in the plastic dash so that when you lay down the first coat of fleece the resin has something to grip on to. then you stretch the fleece over it, resin it, lay down fiberglass, resin. did about 7 layers of fiberglass. i first used short haired fiberglass to fill any holes that were more then 1/8 of an inch. i then sanded and used regular body filler. then i sat there for like a friggin week straight dry and wet sanding to getting all the highs and lows out. then i went and primed it and used glazing putty for all the pin holes and then finally after that i primed it again to make sure all the holes were filled then i threw down the final coat. whew that took a while to type. over all it took me about two weeks from start to finish
Attached Thumbnails fiberglassed 4th gen firebird dash pics-img_0427.jpg   fiberglassed 4th gen firebird dash pics-img_0428.jpg   fiberglassed 4th gen firebird dash pics-img_0429.jpg
Old Jul 9, 2006 | 01:15 AM
tuske427's Avatar
Car: 1984 Trans Am
Engine: 2002 LS1
Transmission: 6 speed
Axle/Gears: 3:73
looks like a lot of work and looks like you did a great job..... "but" I would reccomend you repaint it to a matte or satin finish atthe most. The gloss finish will only reflect the sunlight into your eyes as you drive. just my opinion
Old Jul 9, 2006 | 10:25 AM
blk91z's Avatar
Engine: 5.7
Transmission: 4l60
tuske427: hey i was actually originally planning on a semigloss coat, but a lot of ppl told me that the finish on a gloss coat is much more durable then a flat or semigloss finish. can anyone shed some light on this?
Old Jul 9, 2006 | 12:32 PM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
how much would you charge to make me one? but with out the touch screen part, just lookin for the stock ls1 firebird dash in fiberglass.
Old Jul 9, 2006 | 12:39 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
ZROLimitracing, all 4th gen firebird dashes were the same.
Old Jul 9, 2006 | 12:52 PM
morbital's Avatar
Car: '89 Camaro RS
Engine: 5.7 LS1
Transmission: 6 SPD.
Axle/Gears: 3.25
i am interested on how it would look like on the final installation. even though i am a camaro fan but the 4th gen dash on a firebirds look pretty slick. put some pics on how it looks like completed!
Old Jul 9, 2006 | 01:52 PM
i know they are all the same...
Old Jul 9, 2006 | 02:04 PM
blk91z's Avatar
Engine: 5.7
Transmission: 4l60
zrolimitracing: i dunno if im up for making another one right now, maybe later on down the road. cost in products alone was about 250 bucks. before i start producing them id have to perfect the way i fiberglass them first. when i ripped off the outer skin there were areas like around the vents that took off an inch or so of foam so id probably have to get a little better with close cell foam first. im kinda a perfectionist so i couldnt sell a product that i wasnt 100% satisfied with
morbital: haha im a camaro guy too i just like the firebird dash 100 times better then the camaro ones
Old Jul 10, 2006 | 12:12 AM
tuske427's Avatar
Car: 1984 Trans Am
Engine: 2002 LS1
Axle/Gears: 3:73
I haven't heard of that. What I am aware of, however, is that there is a difference in the paint if you polish it versus sanding it and leaving it that way. The guy who painted my Belvedere (owns a body shop and has been doing this work for decafdes) told me that it is not a good idea to sand a part to achieve a dull finish. apparantly the sanding leaves the paint with open pores (for lack of a better technical description) and when you polish it, it closes them up. So, if you were to go after the flat finish, don't just sand your gloss paint- use a flat paint, whether a dull clear coat, or dull top color coat.
Old Jul 10, 2006 | 04:43 PM
Firebat's Avatar
You or anyone else would have a good market if you just made the top dash part and sold it. The top dash goes for over $100 and usually cracks soon anyway.
Old Jul 10, 2006 | 08:21 PM
blk91z's Avatar
Engine: 5.7
Transmission: 4l60
well now the top dash pad would be a reasonable peice for someone like me to fabricate. two things come to my head when i thing about producing them, how many ppl have a 4th gen dash in a 3rd gen, and how would i create a textured finish on the peice after fiberglassing it. i know theres a crinkle paint and textured paints but like i said im a perfectionist and i would only sell something that matched exactly and made it look like a stock peice. is there anything im missing to create that textured appearance
Old Jul 10, 2006 | 08:39 PM
Firebat's Avatar
actually, i'd be more interested in a non-textured top dash. I don't think the top part is that textured anyway.
Old Jul 11, 2006 | 02:00 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
that looks 100% professional and awesome... good work!
Old Jul 14, 2006 | 11:34 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
That looks awesome, can't wait to see it installed!!
Old Dec 12, 2006 | 08:07 PM
Black is Best's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
That looks awesome.. Do you have it installed yet??
Old Dec 13, 2006 | 03:49 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
WOW. Cant wait to see some pictures of it installed. LMAO. I can only think of the way its going to change that interior COMPLETELY.
Old Sep 7, 2021 | 03:53 PM
Chris747's Avatar
Car: 1995 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: 342
Re: fiberglassed 4th gen firebird dash pics
Do you sell these If so please contact me.
Old Sep 7, 2021 | 09:18 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
This ad is 15 years old.
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Casey Meyers
Mar 2, 2016 10:46 AM
transam84
Aug 14, 2015 08:54 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
