body seam sealer coming off
Old Jul 10, 2006 | 04:10 PM
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
has anybody had the body seam sealer on the firewall, under the cowl, and/or under the carpet come off. i pulled the carpet to install a cage, and noticed it there first, then in the other areas. what is the best fix for this?
Old Jul 10, 2006 | 04:23 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
grind it off and add new stuff
Old Jul 10, 2006 | 04:25 PM
bowtienick's Avatar
what would be good, regular caulk, or do i need something else?
Old Jul 10, 2006 | 04:28 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
3M Automotive, Marine and Aerospace : 3Mâ„¢ Seam Sealers
just a suggestion
theres other things that you can use, but you want something that remains flexible and still keeps the moisture out.
Old Jul 10, 2006 | 04:44 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
i used gasket sealant. Sounds redne<k but it worked for me. just dont get too carried away.
Old Jul 10, 2006 | 04:46 PM
j dezzy's Avatar
Car: 87 TA
I'd use RTV sealer
Old Jul 10, 2006 | 06:53 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Use a good quality urethane seam seal. The stuff from the 80's and early 90's is pure garbage. It dried out and cracked and fell out, which is exactly what you are experiencing.
Any good autobody supply store will carry something.
As with all body supplies...you get as much out of it as you want to spend. You COULD spend 40 bucks each tube, and get 3M AUTOMIX 2-part (similar to their plastic repair, and uses the same gun.). BUT, you'd have to buy the gun, AND it would probably take a couple tubes....
Edit: Follow the link that 87CIZ gave you, It has every sealer you'd want.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
lakeffect2
Aug 23, 2015 08:44 AM
Street Lethal
Aug 13, 2015 08:28 PM
Amillionoh7
Aug 7, 2015 01:24 PM
