Door swap
Old Jul 20, 2006 | 08:49 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Door swap
Well this weekend i found a door for my 1984 pontiac firebird, its off a 1985 chevy camaro, its non powered like my car so that wont be a problem, but will it fit my bird? Also do the door panels on my car fit the camaros? Any advice will be much appreciate and if you pros could give me some tips when swapping the doors. Thanx
Old Jul 20, 2006 | 08:55 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Everything should swap over without too much trouble. You may want to swap the bracket for the arm rest over to your new door, I've swapped 3 doors, and had to swap the brackets on all of them
Old Jul 20, 2006 | 09:07 PM
Car: 84' Trans Am
Is it hard to swap that out, it looks like a pain to put in a new door handle and swap my lock.
Old Jul 20, 2006 | 09:36 PM
j dezzy's Avatar
Car: 87 TA
taking the old door off, swapping over all teh old thing such as the handle and lock, not that hard. the pain is getting the door lined up. the window too if you swap it over.
Old Jul 20, 2006 | 10:11 PM
Car: 84' Trans Am
No, the window seems to be alright so ill probaly keep it in that door, but also i would like to replace the weather striping along the window, Also do you guys recommend me putting in new hinges?
Old Jul 20, 2006 | 11:00 PM
j dezzy's Avatar
Car: 87 TA
unless the door was hanging pretty bad the hinges should be ok. but I always recomend replacing the hinge pins. you can get a good kit from Top Down Solutions.
Old Jul 20, 2006 | 11:05 PM
Car: 84' Trans Am
cool. ill check it out
Old Aug 18, 2006 | 07:35 PM
Camaro1917's Avatar
I got a set from TDS, wasnt what i needed... I would only order for one door to make sure it works for you, then if it does, order teh other side..
Old Aug 18, 2006 | 09:18 PM
Car: 84' Trans Am
Only need the driverside, passenger side is still strong.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
