GTA Wheels Question
Old Aug 7, 2006 | 08:07 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
GTA Wheels Question
I know that our cars need different front and rear offsets for their wheels. I know that Ronals are all the same offset, but use spacers in the front to make up for the difference. I am wondering if you can do the same with GTA rims? For example, if you had a set of four rear GTA wheels, could you run a pair up front with a spacer?
And, for the record, what is the difference in offset between front and rear?
Thanks a lot.
Old Aug 8, 2006 | 09:33 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
IIRC the offset difference is 16mm on the GTA wheels. and yes you can run rears on the front with spacers. I am counting on added track width from my new hub/brake combo to run 4 rears on the car so I dont need spacers for the GTA wheels or for the R15's.
Old Aug 8, 2006 | 10:33 AM
Bull's Avatar
Engine: LT1; None
Thanks for the reply.
I am guessing I'd also need longer lug nuts, like they have for the front of a set of Ronals?
Anyone know the part number of a lug that would work?
Old Aug 8, 2006 | 11:09 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I can look on the invoice for my hubs for the ARP number for the lugs but if you want to look on your own the lugs are M12 x 1.5 thread pitch. Any of these except the toyota ones are close. I dont know the knurl diameter you would need Summit
Old Aug 8, 2006 | 02:50 PM
luisote's Avatar
Car: Camaro IROC-Z 1987
Engine: 454 BIG BLOCK
Transmission: TH700R4
Axle/Gears: 3.42 gears Posi trac
IROC wheels are 16x8 on 4.75 bolt pattern and in front they have a backspace of 4.75 in. and in the rear they have 5.25 in. of backspacing
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
