car got keyed need suggestions
Old Aug 21, 2006 | 10:20 PM
blackfbody19's Avatar
Car: 89 firebird
Engine: 2.8 v6
my car got keyed today and i was thinking to get it out i was gunna try a rubbing compound( i think its just the clear) and the wax the whole car. im hoping this will help hide it a lil but im not shure ...any suggestions
Old Aug 21, 2006 | 10:26 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
first go get yourself a nice metal bat, and take care of the people that did it polishing compound or rubbing compound might take care of it, but depends on how deep scratches are. Let me guss you dont have full coverage
Old Aug 21, 2006 | 10:29 PM
Car: 89 firebird
Engine: 2.8 v6
thats a negative on the full coverage
Old Aug 21, 2006 | 10:42 PM
bnoble's Avatar
Car: '91 Firebird Formula
Engine: 383 w/ BW S400 turbo
Transmission: TH400
Axle/Gears: QP 9", 35 spline, spool, 3.15:1
Run your fingernail across the scratch. If it catches, it's definately too deep to buff, and probably too deep to wetsand out. If only the clear is scratched, that should make fixing it a lot easier. You could probably buy just the clearcoat part of those 2 part scratch fix systems sold in most auto parts stores, fill in the scratches, wetsand smooth, and buff back to normal. I've never used that stuff though (I assume it's a lacquer), so hopefully someone who knows a bit more can chime in and give you a yea or nay on trying it out.
Sorry to hear about that, some punk needs a good beating.
Old Aug 22, 2006 | 01:14 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Nah, just climb under their car and drain the oil, trans, and coolant
I'm just playing, don't take that seriously. As for the scratches, I found this GS-15 scratch remover or something along the lines of that. Its works surprisingly well for fixing clear coat scratches or taking off the crap thats been spot welded there by the sun (some of you know what I'm talking about). Its good in a pinch if you don't have a buffer or similar device on hand. I always worry about this happening to my car when I drive it to school. I want to get a lockable gas cap to keep people from puttin crap in my tank.
Old Aug 22, 2006 | 09:19 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
it just depends how deep the key scratches are. Chances are....the sratches went through the clear, base, and primer. In that case, those areas will have to be sanded, feathered, and repainted
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
mizz0313
Aug 12, 2015 06:45 AM
ZsTransAm
Aug 11, 2015 07:30 PM
Kaweh
Aug 9, 2015 02:54 PM
