Replaceing Reverse light
Old Aug 21, 2006 | 10:47 PM
8IROC-Z6's Avatar
What is the easiest way to just replace the reverse light bulb i dont want to mess around with taking things off that don't need to be.
Old Aug 21, 2006 | 10:57 PM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
There is non, you need to pull off the rear panel and you see black wing nuts, unscrew those and the tail light should be out, and then unplugg the socket and installing is simple.
Old Aug 21, 2006 | 11:13 PM
8IROC-Z6's Avatar
so once i get the wing nuts off the whole unit will then pull out?
Old Aug 22, 2006 | 01:07 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
yep, I don't know how camaros are (I'm guessing you have a camaro by your name), but on the firebird you have to take some panels off in the trunk and there are 6 wingnuts per light assy. On the left assembly however, you have to contort your hand a little bit to get to the wingnuts.
Old Aug 22, 2006 | 09:38 AM
MavViper's Avatar
Ya, on the Camaro take the back panel that covers the latch assembly off and you will see black wingnuts holdin the light in. Take those off and the light assembly will be able to pull out.
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
mizz0313
Aug 12, 2015 06:45 AM
Omega
Aug 10, 2015 12:46 PM
hokis
Aug 9, 2015 03:57 PM
