fender help?
Old Sep 19, 2006 | 09:16 PM
FireBirdBoy's Avatar
fender help?
is there any chance that i can put a set of front fenders off of an 87 trans am, the ones with the vents on them...can i put those on an 89 formula will they line up correctly since the trans am have a different nose than the formulas?
Old Sep 19, 2006 | 11:03 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
I have put the vent type of fenders on my 88 Firebird, it came with the non vented style. I can tell you it's not too hard, you just bolt them on.
All of the mounting points are the same, you should be able to adjust for a nice fit.
the only thing to keep in mind is if you have ground FX, because the mounting holes may be different.
hope this helps
Old Sep 20, 2006 | 08:38 PM
ya that totally helps thanks man
Old Sep 23, 2006 | 04:44 AM
83 Crossfire TA's Avatar
The TA fender will have holes for the lower body work that you’ll have to fill on the formula…
morrow
Jan 13, 2024 12:29 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
kkirch15
Interior Parts Wanted
Oct 15, 2015 02:21 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
