Door Questions
Subscribe
Oct 19, 2006 | 07:39 PM
i have questions on both doors on my bird. the drivers side door makes a "pop" everytime its opened it sags a bit too, is the saging the cause of the pop?and the passenger door dosnt quite shut flush to the body. is there anyway i can fix that?
Reply 0
Oct 19, 2006 | 08:40 PM
The roller bearing on your botton hinge is causing that poping sound. It must be jammed. It is a replaceable part at your local GM dealer.
Reply 0
Oct 19, 2006 | 09:10 PM
i think the sound is comming from where the door meets the fender. will the bearing still stop the pop?
Reply 0
Oct 20, 2006 | 08:27 PM
my driver door used to pop. the door was dented and it would hit the fender and kinda snap it back when i would open or close it. i fixed this by grinding a little off the back of the fender...i would reccomend moving the door back a little bit tho b/c the fender split where i grined it down so i had to replace it
Reply 0
Oct 20, 2006 | 08:55 PM
Ya, the bearing is located on the lower hinge, right next to the fender. If your door isnt dented and is correctly alligned, the bearing is your problem. Note that to change it, the door will have to be removed.
Reply 0
Oct 20, 2006 | 08:59 PM
is the bearing like behind the hinge or something? b/c i just had my door off and put a new one on and idk what your talking about.. help
Reply 0
Oct 20, 2006 | 09:49 PM
there could be a few things up
1 is the bushing (you can get the repear kit at a autozone $ like 14$) you would have to bang out the old door pin, drill the hole in the hinge bigger for the new bush to fit.
2 the spring could of popped out or is on the way of popping out, the lever where the spring goes could be lose or worn(this is the spring end that is closer to the jam)
3 the worse thing that it could be is it being the top hinge if it's worn that means that welded top hinge needs to be replaced.
the first thing you should do is open the door a bit not all the way loosen the hinges top and bot then put a car jack at the bot of the door near the handle and jack it up a good amount and tighten the hinges up again see if this works( you might have to take off the fender i did when i replaced my hinges and adjusted the doors.
Reply 0
Oct 23, 2006 | 09:14 PM
ok, well im gonna replaec the bushings and bearings on the drivers door beacuse of the door sag. the paint on the kick panel is worn off, does the door sag lead to some particular worn out part?
Reply 0
Oct 23, 2006 | 10:35 PM
To diagnose whether the the upper or lower hinge pins and bushings (or both) need to be replaced, have someone help you. Open the door and have them raise and release the bottom of the door while you inspect the upper and lower hinge pins and bushings with a flashlight for movement. If you need more info, do a search for "door hinge pins" using my username. I've covered the topic several times. I sell all the parts and tools to tackle this.
Lon Salgren
Top-Down Solutions
Reply 0
Oct 24, 2006 | 11:17 AM
okay, ill check the bushings/bearings next time i have someone to hold the door
Reply 0
Subscribe
