gta fenders on a maro
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
is it possible to get the gta (at least i think thats what they are) fenders with the scoop on the bottom onto an 89 camaro or no? could you just cut a hole for them and mold them into place or what? i really really want to do this after seeing jjlabinski's car. please help!
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
That would be a custom mod, the fenders are different and don't directly swap, you have a different body line on the camaro fender to contend with thats not on the firebird fender + the fender lip is different..
Engine: 305 TBI LO3
i knew the whole fender wouldn't fit on my car. my question is can i modify my fenders and just put the scoops from that style fender into my fender?
Car: 99 Camaro
Engine: LS
Axle/Gears: 3.25 9"
Sure it can be done just graft the section out of the bird fender into the camaro it would take a bit of skill to cut and fit then weld it in and finish the panel but it's done all the time ..
Beter to use a card board template taken of a GTA & then transfer those to your car. after doing this cut the hole with a dremmel tool after that you can install the scoops either by fastening or fuixing them with some epoxy.
osvaldo
osvaldo
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
GTA & Formulas had no vents.
As far as grafting the vents, it can be done.
Sickness91Z28 is the most prominent one that sticks in my mind... try PM'ing him for details.
Quite old post about it...
https://www.thirdgen.org/forums/body...er-fender.html
Engine: 305 TBI LO3
oh my bad...i dont know a whole lot about birds. i had a 84 t/a that didnt have them but that was a while back. thanks again
morrow
Jan 13, 2024 12:29 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Navy8125
Interior Parts Wanted
Sep 23, 2015 01:11 PM
