T-Top center bracket?
Old Nov 11, 2006 | 11:37 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I'm not sure if that's the correct name. Anyway what are the chances of remomoving it without ripping the rubber seals. I want to sand it down (a little rust) and repaint it and put it back.
Thanks for any tips or advice.
Old Nov 11, 2006 | 01:05 PM
novatuc's Avatar
Car: 1984 Trans Am
It's spot welded in there so it would be a lot of work to remove. Better try to paint it in place. Plus it may be tough to get the rubber weatherstrip out without destroying it (the rubber). It is probably glued in.
Old Nov 11, 2006 | 01:17 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Is this the PART you are talking about?
If so, mine was just screwed in with 6 or 8 screws. Couldnt get mine out, stripped screw head. And the weatherstripping is, or should, be glued on to it. If you try to take it out plan to replace the weatherstrips.
Old Nov 12, 2006 | 04:48 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Mine is more rusted than I thought but I got a good one at PICK YOUR PART. I going to have to wait until I can afford new weatherstripping though. They want a ton of money for it.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
m00n420
Sep 11, 2015 02:39 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
