replacing a door with fender still on?
Old Nov 15, 2006 | 08:58 AM
djtricia's Avatar
Car: 1986 Z-28
How hard is it to replace a door on an 86 Camaro with the fender still on? My passenger side needs replacement and Iwould like to avoid taking the front end apart to do it.
Thanks.
Old Nov 15, 2006 | 09:00 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
not hard at all. Its gonna take time to get to all the bolts on the hinges, but not a big deal. Every thidgen is the same. I have a 92 and did it with no problem. I took my whole car appart, but I think I took the doors off first (3 years ago)
Old Nov 15, 2006 | 09:42 AM
djtricia's Avatar
Car: 1986 Z-28
Thanks!
Old Nov 15, 2006 | 10:10 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
make sure to run some tape along the edge of the fender...so if you accidently rub against it...the paint won't chip
Old Nov 15, 2006 | 11:02 AM
djtricia's Avatar
Car: 1986 Z-28
That makes good sense.
Old Nov 15, 2006 | 11:21 AM
slim64's Avatar
Car: 64 Impala, 86 Z28 Camaro, 00 C5 FRC
When i took the doors off my parts car the fenders were still on, to get to the bolts on the doors i took the plastic inner fender pieces out, that gave me access to the bolts from the front. the hardest part about all this is going to be getting the door back on and aligned. good luck!
Old Nov 15, 2006 | 12:15 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
yeah allining the door is the hardest part
Old Nov 15, 2006 | 01:16 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
It's easier to get it to re-align if you scribe the outline of the hinge to the body.
Old Nov 15, 2006 | 04:43 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
It took me and my bro to align it. I pulled up and back while he slid the bolts in. Those doors get really heavy really fast. Be careful.
Old Nov 15, 2006 | 10:25 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I used a rolling floor jack to hold the door level while i tightened the bolts.
Old Nov 15, 2006 | 11:56 PM
MOTOCROSS's Avatar
Car: 1984 Z28
Engine: 355
I used an engine puller with a leveler and two tiedown straps. Once you get the holes lined up, start the two forwardmost bolts first. If ya don't, it's really tough to get the other two bolts started. It took me maybe 30 minutes by myself. Love them 3rd gen doors!
Old Nov 16, 2006 | 07:24 AM
djtricia's Avatar
Car: 1986 Z-28
Thanks for all the replys. With my bad back I'll make sure to get an extra hand or two.
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
tecustomz
Aug 16, 2015 02:28 PM
