Is this fixable?
Old Dec 1, 2006 | 11:02 AM
joshk879's Avatar
Car: Looking for a project
Is this fixable?
Ive got an opportunity to pick this car up for free. Its a 91RS. It would be perfect for the project im going to start. Im just wondering if I should or not based on the damage.
http://www.robertg.org/images/91rsshell/
Old Dec 1, 2006 | 11:09 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
How bad is the car you have now josh?
Post some pic's of it also.
Old Dec 1, 2006 | 11:24 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
yeah its fixable, the sheel seems to be in decent shap other than the floor, but that needs alot of parts and work
Old Dec 1, 2006 | 11:35 AM
joshk879's Avatar
Im not really worried about the amount of parts and work needed. This is going to be a long term project. Only thing that concerned me was the floor.
Old Dec 1, 2006 | 11:36 AM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
If you know your way around a welder, that is some very easy work to do. Because most of it will be hidden, you are not going to have to worry about making everything look PERFECT. Also, what you might want to consider is on those tricky spots like around the jam corners, you could always go the the junk yard, cut out the metal you need and weld the exact peice in your car.
For free = hell of a deal
Old Dec 1, 2006 | 12:21 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
MAn, I must say that is an amazing attitude!
You have an opertoonety to practicly re-design the car, however you want to do it. When your done, it will be perfect for you, Good Luck!
Old Dec 1, 2006 | 12:32 PM
luke-gr's Avatar
Wow! Aint much there. Funny you should post that. I started cutting into my TA last night that has problem in exactly the same spot. Mine is near identical. Kind of a tough spot for my first bit of welding bodywork, but it is hidden...... There are several pieces of metal that come together right there and it has been like peeling an onion. I jsut bought a spot weld cutter today.
Good luck!
Old Dec 6, 2006 | 07:15 AM
joshk879's Avatar
I think im going to give it a shot. I do have a donor car for doors, dash, hatch and so on. So far that stuff its just a matter of swapping it over. The donor car i have now was going to be initially used for the project. But the rust is worse, plus it has a sunroof. At the start i was going to patch the sunroof in the donor car, but i think going with the red RS will be better.
Old Dec 6, 2006 | 08:23 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
If you're starting a project from the ground up, two cars are definitely better than one!
Old Dec 6, 2006 | 09:08 AM
Car: 1979 Malibu
Engine: Blown LSx
and if the floors in the other parts car are good, then you got factory sheetmetal to work with too!
Old Dec 6, 2006 | 02:15 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
hehe,, plus all the parts I have you can use....
Old Dec 7, 2006 | 11:04 AM
joshk879's Avatar
yup
Old Dec 7, 2006 | 12:52 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
it would be a good rebuild if you have the time and money to put into it and its the best price FREE
Old Dec 16, 2006 | 06:24 PM
89rocket's Avatar
Car: 1989 RS
Engine: 2putt8
wish i could start with a bare shell like that. less tear down.
80smetalfan
Sep 22, 2015 02:55 PM
Blkdth87
Sep 16, 2015 01:40 PM
88txiroc
Apr 16, 2003 01:48 PM
BikertrashDude
Mar 21, 2003 05:45 PM
dowtyt
Mar 14, 2002 07:13 AM
