4thgen rear hatch latch
Old Dec 12, 2006 | 11:17 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Has anyone tried to use the manual rear hatch locking mechanism from a 4thgen to replace the motorized 3rdgen latch? Mine still works .....knock on wood... , but I wonder if it would work?
Any takers?
Old Dec 13, 2006 | 06:02 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Has anyone tried this or am I going to have to be the 1st to finger it out?
Old Dec 13, 2006 | 06:24 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Looks like you're going to have to finger it out Mike and when you do please share.
Old Dec 13, 2006 | 08:01 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Why would you want to try to make the 4th gen one work when you can just use a non motorized thirdgen one? Seems to make more sense, or at least to me. They were on the earlier cars, I think 87ish it beacme a standard option.
Matt
Old Dec 14, 2006 | 04:16 PM
MNformula350's Avatar
I swapped out my power pull down for a Manual altch like the 82-85 3rd gens had.
I had to weld in the mounting bracket from the manual car, but other than that it is pretty straight forward.
Old Dec 14, 2006 | 10:28 PM
Firebat's Avatar
Can the older style thirdgen non-motorized hatches be open with a trunk switch?
The 4th gen hatch can be opened by a switch.
Old Dec 14, 2006 | 10:32 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Good question! That is the reason why I suggested the 4thgen latch. I wanted to wire it to my hatch popper switch.
Old Dec 14, 2006 | 10:47 PM
yes the non powered third gens ones still pop with the switch. my buddies 84 has the non power one with the same switch between the window switches.
matt
Old Dec 15, 2006 | 01:56 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Cool. Then it would probably be easier to use one out of an '84.
Old Dec 15, 2006 | 12:46 PM
3vi1p3nguin's Avatar
Car: 85 Iroc-Z
Engine: 350 4bbl
not all of the manual ones pop by a switch, the one in my 85 doesnt
Old Dec 16, 2006 | 06:24 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Fourth gen one won't work either. Aside from mounting differences, the way the lock cylinder works is completely different.
Kevin D.
Old Dec 17, 2006 | 10:56 AM
A car not originally equipped with a hatch release, can have one added.
All you need to do is add the solenoid to the latch assembly, the relay and switch.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
