Rear quarter skin replacement
Old Dec 16, 2006 | 02:14 PM
Madcrazy's Avatar
Car: '91 Formula
Engine: 5.0 TBI
What is the general cost to replace the rear quarter skin? theres really not a whol lot of damage to anything but the skin and looks like it would be pretty painless to do. all i want is it to be replaced and primered.
Old Dec 16, 2006 | 03:33 PM
92fbodylover's Avatar
Car: 92 rs camaro ,92 covt trans am
Engine: 305 tpi , 305 tbi
Transmission: auto
not to hard at all. When I do it on customer cars I do the welding in jams or underweather stripering so it helps hind the repair. Just have to do a wash job to make sure you got all the welding good, last thing you want is a nice replace being notcieable by water collecting in the cargo area. I have quarterpanel for sale 100 per side. Let me know
Old Dec 17, 2006 | 02:53 PM
Madcrazy's Avatar
Car: '91 Formula
Engine: 5.0 TBI
I am getting one for $75 but i dont have the tools to even attempt such a project and i was just wondering what body shops usually charge to do it
Old Dec 17, 2006 | 03:55 PM
1320-camaro-383's Avatar
Car: 91 camaro
Engine: 383 demon 750 rpm heads 150 shot no
Transmission: bto 700r4 stage 3
Axle/Gears: currie 9" 4:10 true track
I paid $1200.00 about 5 years ago for one side.That was at a high end body shop however I went with aftermarker insted of oem,what a mistake.Spend the extra and get oem!!!!!!!!!!!!!!!!!!!!!!!!!First of all where the rear quarter met the hatch on the stock side they were about 3/16 straight gap on the replaced side the rear quarter went at an angle from about 1/8 to 5/16 maybe even 3/8.Thats a lot in a 1 inch piece.For second the replaced quarter stuck out quite a bit further than the origanal.It just didnt look right.It bothered me so much for this reason and a few others I started over with a new shell and scraped that one.OEM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 17, 2006 | 06:44 PM
Transmission: auto
i charged the guy 700. and that was more than just the panel. That was to cut, replace quarter panle, and replace the door on the driver side. Then after winter he gave me another 7000 to side that side
Old Dec 17, 2006 | 06:56 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Im going to attemp the same thing in the spring. I want to do both sides. I have a good welder and a spot weld cutter. I probably should get another cutter cause I iamgine there are alot of spot welds to cut out.
Old Dec 17, 2006 | 07:23 PM
Craig H.'s Avatar
Eastwood sells nice spot weld cutters...good luck.
Old Dec 17, 2006 | 11:17 PM
Kandied91z's Avatar
do they even sell oem anymore? i've heard stories of 8-900 a piece. i know i pass on all cars with them rusted out because of their cost.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
BlackTopKing
Aug 19, 2015 12:13 PM
Exxon Limited
Aug 9, 2015 08:13 PM
