Half bakery maybe? Suicide lambo doors
Old Dec 17, 2006 | 12:41 AM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
i'll be stoned for this but considering the already daunting task of lambo/verticle doors how much more difficult or mybe less difficult would reverse lambe doors be. anyone have ideas
Old Dec 17, 2006 | 12:20 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Most the aftermarket hinge systems utilize the stock latches and release mechanisms. At the front of the door you have the room (with some fabrication) and a removable fender. At the rear you'll have to work from inside the car and fabricate the structure to support the door weight. There just isn't anything to weld the hinges to. There is less room for the gas springs as well. Installing them can be a challenge with nothing in the way. Then there is the curvature of the body you need to get the door to swing up and around.
The outside handle should be moved to the front of the door or replaced with an electric release. The inside handle could be electric or switched to a cable. The latch mounting will have to be completely fabricated with attention paid to getting it mounted on the correct angle to match door swing. Then the striker post mount will have to be fabricated to match and be strong enough for safety in a crash.
Once complete getting in the back seat will be much more difficult. Might be easier to close the door though from a seated position. I had a lot of fun installing my normal front swing vertical hinges without having to touch the latches. It looks cool as hell. My opinion, the added impact of reverse swing isn't worth the added aggrevation. But then there is the challenge...
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
Veaceonee
Sep 29, 2016 08:15 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Buggy Disaster
Sep 17, 2015 05:12 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
