Front nose swap?
Old Dec 31, 2006 | 03:04 AM
84CamaroSS's Avatar
Car: 1984 Camaro
Engine: 350 bored .30 over
Transmission: TCI 700-R4
Axle/Gears: Stock 3.23 i think
Front nose swap?
Im switching my 84 coupe bumper for a 87 Iroc bumper what would be my first steps anything i need to know before hand?
Old Jan 4, 2007 | 05:51 PM
ChrisColeman's Avatar
Should swap right over. Does your car have ground effects? The ground effects are different between the two but Im sure they swap over. And the plastic clips that clip the bumper the the reinforcement are a pain in the ***. Also, The black plastic piece that the headlights mount into comes off with the bumper. You'll attach that to the new bumper and then bolt them both back to the car. To get started you remove the plastic cover in front of the hood latch and start pulling bolts. Post up if you need more info.
Old Jan 9, 2007 | 05:54 PM
DIABLO NEGRO's Avatar
Car: 1985 project SC
Engine: LSX (planning stages)
Transmission: (planning stages)
Axle/Gears: (planning stages)
id get some shims and check the spots where the ground effects (if it has the skirting) go into the fender are there if not you'll need to make the elongated holes.
Old Jan 9, 2007 | 07:53 PM
Sickcuban's Avatar
Car: 1984 Camaro
Engine: LG4 305 - Conversion Commencing
Transmission: TH700-R4
Axle/Gears: 4.10
He has the same car i got. there are no ground effects so u should be fine
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
