Painting At Home: Need Help With My Product List
Old Jan 30, 2007 | 11:12 AM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Im trying to make out a list of all the things im gonna need in order to paint my car at home, Its a father son project with my dad and step dad. They have left me up to getting all the equipement and needed materials(gotta Learn )
So far this is what I got from http://www.harborfreight.com/
ACTION SANDER 29.99 29.99
1 9588-4VGA 50 LB. CAPACITY ABRASIVE BLASTER 44.99 44.99
1 43430-2VGA HVLP GRAVITY FEED SPRAY GUN 64.99 64.99
1 46653-9VGA 6'', 80 GRIT PSA BACKED SANDING DISCS, 25 PC. 3.99 3.99
1 46655-0VGA 6'', 180 GRIT PSA BACKED SANDING DISCS, 25 PC. 7.99 7.99
1 91860-2VGA 20 PC AIR COMPRESSOR STARTER KIT 13.99 13.99
1 92504-0VGA 4HP, 29 GALLON COMPRESSOR 399.99 399.99
1 92945-2VGA 3-IN-1 AIR RATCHET KIT 17.99 17.99
1 93428-1VGA 70 GRIT ALUMINUM OXIDE ABRASIVE, 25 LBS. 17.99 17.99
Subtotal 606.90
Im trying to get together everything I need to get the car into primer, I'll worry about the actual paint and bondo locally, Im mainly looking for equipement through this place. The T-Tops have some surface rust and a couple small rust holes so thats what the sand blaster is for, but im wondering if thats enough material for the blaster though. Im also taking the car to bare metal and its factory paint so what grits of DA paper do i need and how much?
Fell free to list or even tell me if i have anything i don't need or need more of,
Stuff I think I Still Need:
1.)sanding boards
2.)sand paper(what grits?)
3.)masking tape(various sizes)
4.)i think i need some type of water filter for the gun
5.)a spray mask
6.)Primers and Paints
7.)bondo and putty's?
8.)Roll of paper for masking off the car
9.)Good Set of hands
10.)Latex Gloves
11.)Lint free rags for whiping down the car before paint.
12.)wax and oil remover
13.)Good Paint and body book
14.)I need some help
I Really Need Help
Old Feb 16, 2007 | 09:29 AM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
your on the right track, go to autobody101.com they have alot of info.
oh and when you buy bondo, don't buy bondo brand there are alot better brands out there...
Old Feb 16, 2007 | 11:49 AM
MrHorsepower's Avatar
Car: 89 Firebird
Transmission: auto
Axle/Gears: 3:73
I'd find a bigger compressor to start out with. The one you chose is a lil on the small side. And for that price you can get one that will do the job from cummings tools.
And that auto body site rocks. lol
Old Feb 16, 2007 | 10:28 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
The compressor is big enough to paint with, but totally insufficient
for sandblasting anything larger than 1 sq. ft. at a time, or
continuous hi-flow tools like a sander. Learn what cfm your
tool need, and what cfm your compressor provides, per stated
duty cycle. The March issue of Chevy High Performance has
several good articles about DIY painting. You're list is a good start.
The air tools are available from a wide variety of suppliers, and
you'll pretty much need to educate yourself. A good moisture
filter & regulator is a must for painting. As for the specific supplies,
look for a good supplier locally, that will spend time educating you.
And since you're starting from ground zero, allow for another 3 - 4
franklins, before you even get to the color paints.
Good luck, and keep up posted.
Old Feb 17, 2007 | 11:49 AM
Pocket's Avatar
Car: 91 Trans Am
Change your face mask to a big box of face masks, you wont want to reuse
them
You also need the clear, clear hardener, and a bunch of small buckets
Paint strainers
Grits change for whatever you plan on doing
If your goin to bare metal Id suggest 60-800 about 3 packs of each kind
Grits below 300 you should get dry paper, 300 and up should be wet paper
Go to the tools section in Lowes, they sell water filters and something you didnt add was a pressure regulator. Roughly $80 for the both of them
The air tools youll prolly not use too much. I used a jitterbug electric and the spray gun. Food for thought, thats all
Good luck
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
Catcher55
Aug 15, 2015 07:08 PM
