Ground effects painting?
Car: 1992 Z28
Axle/Gears: 10 bolt posi. G80
Hi. I am going to attempt my paint job this spring and was wondering if, when you take the ground effects off and paint them. Then paint the car seperatly. Do you put the ground effects back on after how many coats? And then coat the whole car again? Thanks.
Car: 87 Camaro IROC
its best to do the base/clear seperately, depending on your pickyness...you can wetsand them seperately too or you can put them on and then wetsand.
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
I'm in the middle of painting and I have most of my gfx in my basement with filler and primer... your spraying will be easier with the gfx off when you paint and will look better where the effects meet the body.
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
i have mine off of the car now;a nd am having the painter paint them, as well as the hood and fenders OFF of the car completley; then i will install them once everythign is finished; in a month or so
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
Thomas
Oct 3, 2015 05:34 PM
92firebirdchris
Aug 14, 2015 11:56 AM
