light swap
Old Feb 15, 2007 | 06:29 PM
RICEKLR's Avatar
light swap
basically, i want to get brighter lights for my front turn signals. im thinking about 50W or so. anyone know where i can get some bright enought to be headlights that will fit? its '90 model formula.
Old Feb 15, 2007 | 10:20 PM
Kandied91z's Avatar
you want them as bright as a headlight...? you'll need to modify your harness and add a relay to be able to support the amp setup. you can't just stick a 110 bulb in there and call it a day.
i don't condone your idea in anyway but it can be done, you'll have to search the internet a little harder to find out exactly how but basically consider the idea of wiring up another set of headlights to do it.
may luck be with you..
Old Feb 16, 2007 | 09:14 AM
cdoyle's Avatar
you'll also have to worry about the higher wattage bulbs melting the lens too. That's a lot of heat for a lens that wasn't designed for it.
TheJoeY88
Dec 31, 2016 07:30 PM
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
