Windshield wiper help
Old Feb 20, 2007 | 09:18 PM
richardsruru's Avatar
Car: 1989 Camaro RS
Engine: 5.0 liter TBI
So I go and get everything I need to get my 89 camaro back on the road including windshield wiper blades. First off I have an 89 camaro rs with 305 and 700r4. I bought 18 inch blades. I feel really dumb asking this but either way I have to. I looked at the blades on my car and am lost on how to remove them. I looked in my book and did a search. I found nothing. The book said to release a button to remove the windshield wiper blade. All that I have been able to do is remove the blade. I hope that this is clear as to what I am saying. All that I removed is the rubber portion. Is this what is referred to as a refill when you look up the part on autozone.com? Thank you for your assistance in advance.
Old Feb 20, 2007 | 09:38 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Most all newer style wiper blades are held on by a little plastic clip. There are a bunch of different variations of these clips. If you can't figure out how to release them, just break the clip off.
If it's an older style blade that uses a metal retainer, there should be a small tab near where the wiper arm peg goes through (on top of the wiper iirc). Get a flat head screw driver or something under the tab and hold it up as you remove the wiper.
I hope this helps. If it's a different style from the ones I've described, then a picture would give us something to go on.
Old Feb 20, 2007 | 10:02 PM
Car: 1989 Camaro RS
You are correct. There was not a button to press. I just had to pry it off with a screwdriver. Worked great. Now I have two new windshield wipers on my car. Thank you so very much.
codeysabatini
Nov 10, 2015 04:07 PM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
