Rust above window
Old Mar 5, 2007 | 07:46 PM
kronos's Avatar
Car: 89RS
Engine: Lo3 bored.030 over, 230/480comp cam
Transmission: 700r4 10" converter
Axle/Gears: Stock G80 2.73
Rust above window
I have an 89 RS, and I have rust that's been getting worse by the day over the drivers side window. Now my qusetions is, should I cut and patch or grind and fill?
Old Mar 5, 2007 | 07:52 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
I'd say, sand it down, then bondo it.
Old Mar 7, 2007 | 05:18 PM
dtk132's Avatar
Car: 1986 Camaro
Engine: 350ci 5.7L
Transmission: T-5 Borg Warner
Axle/Gears: 10bolt/ 3.42
Whats peoples obsession with bondo???
bondo is a brand name , its body filler and theres a lot better fillers out there then bondo, ever coat or ever lite for ex.
If it were me i would grind that down to bare metal put a rust inhibitor over it such as mort rust.. give it 3 days to dry, wipe it down again, spread a thin thin coat of filller over it, and etching primer over bare metal spots, fallowed by a reg primer, and blend with your fact paint, its not that bad.. id get it now before it starts to spread though
Old Mar 7, 2007 | 06:08 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Bondo is just the easiest to get, and its pretty good priced.
But back on topic, definitely sand it down to bare metal, I forgot to mention that in my other post.
Old Mar 7, 2007 | 07:20 PM
kronos's Avatar
Car: 89RS
Ok thanks for the tips, I'm probably going to grind it, fill it and just prime it. The car needs to be painted so i'll just live with the primed spots for a while. Whoever owned the car previously had a crappy paint job done, there are a couple runs it looks as though they may have done it themselves
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
tcflint
Sep 27, 2015 05:58 PM
