Is this gfx damage fixable?
Old Mar 10, 2007 | 06:00 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
How hard is it to repair them?
I've got a nice notch in the center of mine....
And I read the sticky, but it's a bit vague about things that have material missing, ad there was some dispute as to the best method blah blah.. Im trying to decide whether I should spend the money to grab a fresh front gfx piece or whether this is entirely fixable... If fixable I'll just post pone it to another day, but if it's not I want to go ahead and grab a fresh part while they're available.
But from reading the thread far worse has been supposedly repairable and it really doesnt look too bad to me... I just am not sure what "material" will suffice to fill in the missing part.
Old Mar 10, 2007 | 01:32 PM
Gramps's Avatar
Car: 87 Camaro IROC
you can fix it, just use fiberglass and epoxy (some flexible epoxy) and build up the area and then sand it down. i did the same thing to my chipped areas.
Old Mar 10, 2007 | 09:02 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
I agree with gramps you can fix this. its not in to bad of shape at all. If I ever needed a new one I would buy one in this condition from a yard and repair it myself.
Old Mar 10, 2007 | 09:07 PM
Sunny's Avatar
Car: 1986 Z28 Camaro
Yeah it's easily fixable.. Put something behind it [fiberglass mesh cloth or even like duct tape] then mold it to specification on the front.. My buddy bottomed my car out and snapped one of my GFX in half, and I just fiberglassed it back together and it looks fine.
Old Mar 10, 2007 | 09:19 PM
SickManSeth's Avatar
If you want to get completely and totally **** about it,Glass it as they said up above Patch the gelcoat and repaint the entire front end. The experts won't even know.
Old Mar 10, 2007 | 10:32 PM
Car: 1992 Camaro RS
Thanks guys!
Old Mar 11, 2007 | 11:07 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Is it cracked at all or just scuffed up a little? If it's scuffed....don't use fiberglass. The front ground effects is made form urethane. If you fiberglass it...and it bends in anyway...it's just going to crack. 3M makes a 2 part flexible epoxy for flexible parts. It allows the repair to flex.
If it's cracked:
Scuff up the back of the crack and surrounding area REALLY well. Apply the
3M epoxy, lay down a layer of fiberglass, then apply one more coat of the 3M epoxy. Although your using fiberglass as a "backing" it won't crack because of the 3M epoxy. Then "V" out the crack, scuff up the area really well, then apply the 3M epoxy. Sand down the epoxy, then do your basic body work (using flexible filler) and your done.
You can fix it however you want, but the way I describe lasts and it won't crack.
Old Mar 11, 2007 | 12:22 PM
irocstang's Avatar
Car: 86 IROC
Engine: 5.0
Transmission: 5 speed
id either one plastic weld it or two....put mesh behind it and use a product called Norton Speed Grip on the top. Level it down via sanding....and whoomp there it is....im in the autobody trade
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
