Remove Upper Door molding from panel?
Old Mar 11, 2007 | 04:05 PM
cdoyle's Avatar
Hey,
I got my new door panels this week, and now I want to take the upper door molding off my old panels and put on these new ones. How do you remove these from the panels without breaking the tabs on the molding?
Do they unscrew off?
Attached Thumbnails Remove Upper Door molding from panel?-upper-door-molding_webn.jpg
Old Mar 11, 2007 | 06:17 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I had to use needle nose pliers, and gently twist the metal nuts off. It takes a little patience, but its not too bad.
Old Mar 11, 2007 | 11:49 PM
cdoyle's Avatar
that's what I thought, but I just tried to twist one ever so gently and it broke right off.
GRRRR!! Why did they have to mount them this way.
Old Mar 12, 2007 | 01:12 AM
simo's Avatar
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
Snap-on Nut Driver, Trim, GM
Snap-on sells the removal tool.
Stock#: S9614A
$29.50
Works great creates an even pressure on the inverted nut so the plastic posts should not break.
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
Street Lethal
Aug 14, 2015 08:25 PM
3rdgenparts
Aug 8, 2015 07:09 PM
