replaced upper and lower hinge bushings, now door fits loose at latch...
Old Mar 13, 2007 | 03:28 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
well I just got done installing my bushing kit I bought from Lon, (and this must be said... GREAT shipping! ordered saturday at 3:30 parts arrived on monday. How does he do that?) and after I got them in I had an even worse hang up at the latch. so after a bit of creative looking with a flashlight and feeler, I found out that my latch was engaging just the verry tip of the striker bolt. as in the last 1/8th inch where it is flared. Hmm, that cant be right can it? So I drive over to the local Hardware store, and get a bigger spacer to put between the door jamb and striker bolt to extend it out a bit so the latch hits where it should... Now with my door closed I have about a 1/8th inch play in my door. Looking at my door latch it loks like I should be able to loosen the bolts and push it about 1/8th more into the door to creat a tighter seal when the door is shut, but I couldnt get the latch to move. I diddnt force it as I really dont want to mess up my car any more than I already have with other issues... ( IE read my thread in the exhaust section... stoopid stripped threads...)
any advise?
Old Mar 18, 2007 | 04:04 AM
Car: 89 RS
Engine: 2.8
sweet, no one knows.....
Old Mar 18, 2007 | 10:12 AM
D BERRY's Avatar
Car: 89 Camaro RS
Engine: LO3
Axle/Gears: 273 pegleg
Isn't the striker bolt adjustable, up and down and in, and out??
Dave B
Old Mar 20, 2007 | 06:41 AM
Car: 89 RS
Engine: 2.8
not sure. Ill look into that though. seems like it should be now that you mention it, but if not, I have a dremel. Im sure that I can MAKE it adjustable.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
86IROC112
Apr 9, 2016 10:20 PM
wruiz
Aug 11, 2015 02:59 PM
