90-92 Ground Effects Comming Loose
Old Mar 14, 2007 | 07:32 PM
SMKNTRS's Avatar
My ground effects have been slowly comming looser and looser on the doors. I see that they are riveted to the bottom of the door. The plastic is still in good condition so i was wondering how i should go about fixing it. Do i make a new piece from thin sheet metal? Or i seen that you can use bodyshop grade adhesive to attach them?
Old Mar 17, 2007 | 08:58 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Not that it's off topic here, I'd say it's definitely in that restoration category, but I think you'd get a lot more information/answers if you posted in the body forum.
Old Mar 26, 2007 | 06:30 AM
SMKNTRS's Avatar
Re: 90-92 Ground Effects Comming Loose
oh, thanks. ill have to give that a try
Old Mar 26, 2007 | 08:43 AM
CYARS92's Avatar
Car: 92 Camaro RS, 72 Camaro SS
Engine: 305TBI, til it pukes
Why not simply re-rivet them. A half hour fix.
Old Mar 26, 2007 | 10:00 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
They are not rivited to the door. The rubber GFX have a metal backing plate that is bolted to the door in 5 places. 3 behind the door panel, 2 you can access just opening up the door.
The rubber piece IS rivited to the metal backing plate.
Frozer!!!
Jan 19, 2024 04:55 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
GVMV
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
