ok so i take it you cant perfectly align the hatch glass on these cars right ?
Old Mar 15, 2007 | 03:35 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i jut wanted to confirm that its imposible or at least virtually impossible to perfectly align the hatch glass onto these cars
right ?
before i urethane my hatch deck to my glass tomorrow
currently it is all cleaned of the old urethane and awaiting install but first i wanted to recieve any tips ideas suggestions confirmations and etc regarding alignment
it seems like the curve of the glass doesnt matcht he curve of the body on the passenger side
i dont understand it and cant find a way to correct it, its almost like the passenger side of the glass needs to be raised up, but you cant do that because then the weatherstripping wont seal to the glass,
so..
hum
crazy.,
does anyone on here have a perfectly aligned hatch glass(not talking about the spoiler deck plate alignment)
and i tell you what but whatever engineer decided to use this style of bolts to hold the deck to the glass needs shot because the damn things sometimes break loose and then you cant remove the damn nuts and it pisses you off because you either have to cut them off with a blade or torch the nuts off or beat the hell out of them and use a flat prybar and cuss alot
thats BS
two of them did this to me
but im a perfectionist usualyl, and ill normally do what it takes to accomplish what i want to accomplish
too bad thats only the case for vehicle related stuff, normally
hum
such is life i suppose.
thanks
Old Mar 15, 2007 | 04:29 PM
AmorgetRS's Avatar
According to the GTA source page the Thirdgen is actually built about 1/2" off. So I think that means it can't be perfectly aligned.
"While going over some of the plans for the decklid, one of the people from Auto-Fab said offhandedly to some of the GM people in attendance that they didn't understand the fit problems that were in evidence as A-F had built the decklid "to print" (GM spec). At that time, one of the GM brass piped up and said that was most likely the problem.... since the 3rdGen F-cars were "1/2 inch out in the RH rear corner".
http://www.gtasourcepage.com/newdevelopment.html
Old Mar 15, 2007 | 05:26 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
wow..
thats pretty wild
learn something new every day
usually
thanks!
Old Mar 15, 2007 | 05:40 PM
Stephen's Avatar
Car: 87 GTA
Is it possible to bolt up the glass, get the rear portion lined up, THEN silicone (whatever they use) them together? Seems there outta be a way to line them up correctly, before applying the adhesive that bonds them.
Old Mar 15, 2007 | 05:46 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
well the urethane will be slick enough to slide th deck around to where it needs to be
it sets up fast, but not THAt fast :P
i gotta do this tomorrow i already bought the fast set urethane in a tube today from the glass shop
im ready to go for it, but not today
Stephen it looks like i have some PM's from ya to read and reply to , lol
:P
Attached Thumbnails ok so i take it you cant perfectly align the hatch glass on these cars right ?-march1507-004.jpg   ok so i take it you cant perfectly align the hatch glass on these cars right ?-march1507-002.jpg
Old Mar 15, 2007 | 06:09 PM
DMitchell05's Avatar
Good luck with it Interesting things you learn about the small imperfections which make 3rd gens perfect
Old Mar 15, 2007 | 06:19 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
1/2" is a pretty significant imperfection to me, especialyl when it comes to a body part alignment
heh
crazy stuff,
i should probably pull the two studs that broke loose in the deck plate before i install it, hmmm
that should be the first thing i do tomorrow
and if im lucky i can figure out a way to get two bolts of some kind in the holes and mig tack weld them in
maybe.,
if im so lucky
actually i could probably weld washers over the holes or in the holes and then weld cut off bolts/studs onto those
or actually maybe i could just pull the studs up and hold them in place and get some tacks around them in there possibly, hum.
hmmmmm....
Old Mar 15, 2007 | 08:40 PM
jay92,85,79's Avatar
Car: 85z28,
I hope i word this so u can understand what i'm saying... U can rise the side up some. U can get so shims put them under the hinge. Inbetween the hinge and the metal.. Like you were thinking. You said u could rise the glass up but would not seal.. What you can do is take a hammer and tap up were the weather strip goes. This will make the seal tighter.
One more thing go back to that glass shop and get a bottle of primer for urethane. (not reg primmer)If u do not use it it will leak. Trust me been there done that.
O yeah they are pretty much imposible to get perfect. Thats what makesit a 3rd gen.
Old Mar 16, 2007 | 05:59 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ok thanks good info
im not gonna try shimming the hinge ot raise the glass on this side if its never going ot be perfect
not really a point to it IMHO
the tube of urethane says it is primerless, the primer is incorporated into the urethane
it is DOW primerless quick cure urethane adhesive U-418 HV
60-80 degrees
http://automotive.dow.com/automotive...ts/U-418HV.htm
thanks
Old Mar 16, 2007 | 03:02 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
done, that was pretty easy actually
the only thing that went wrong was one of the two studs i had to tack weld in place on the deck broke loose on me,
but oh well
now i have a grid hatch glass the way it came from factory, and my t/a deck and spoiler back on the car again
i learned that you have no choice on where the deck is located on the glass due to the glass frame ends not being able to be moved, the two screw holes in them have to lines up with the holes in the deck plate, theres no choice in how the plate can be positioned
but its lined up virtually perfectly on the car with it shut, so thats good
Old Mar 16, 2007 | 03:06 PM
Stephen's Avatar
Car: 87 GTA
Sounds like the only way it could be changed, would be to drill new mountings, or enlarge the existing ones.
Old Mar 16, 2007 | 03:16 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yeah, but that would be kinda crazy imho
ive never run across any that were re drilled,
so i assume it never needs to be done
unless something bad is wrong, lol
:P
Old Mar 16, 2007 | 03:20 PM
Stephen's Avatar
Car: 87 GTA
I need to go take pics of how my hatcg is misaligned. I wonder if there is any adjustment available, because it doesn't seem to match with the descriptions of the normal misalignment. Be right back...if my batteries are good.
Old Mar 16, 2007 | 03:38 PM
Gramps's Avatar
Car: 87 Camaro IROC
ppl wont re-drill holes because they cant drill through glass. only thing you can do is get some of those dremmel tools and grind the holes bigger. if you use a dremmel, make sure the tool is made of "silicon carbide", cuz nothing else will work. and when you do it, wear a dust mask because those glass shavings can cut up your insides.
Old Mar 16, 2007 | 03:42 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
no no im not talking about the glass holes lol
i mean the little sheetmetal screw holes that hold the glass frame ends to the deck underneath
hahahaaa :d
i am amused
ive got this one aligned better than ive ever seen any in the past lined up
in pic i posted of the entire rear of the car it looks like its real close to the QP skinon the RH side but its actually not, it actually exact same gap over there as on the LH side, the camera angle makes it look like its messed up lol
the deck doesnt hang past the end of the QP's either, it stops right at them, the way it should be
never seen oen of these cars where it wasnt crooked bad and where at least one end of the deck wasnt hanging past the end of one of the QP's
so im very happy with the results on this, it turned out bvetter than expected, for sure
i have alot of work to do on this car yet still, sanding, smoothing, a QP replacement, paint, and so on, but first i have to get this engine in, and deal with exhaust and find a deeper ratio axle, and go from there,
Old Mar 16, 2007 | 03:47 PM
Stephen's Avatar
Car: 87 GTA
Well, I didn't wanna drink that class of Coke anyways. I grabbed my camera, which turned out the USB cable was still attached, and running behind the glass, which ended up on the floor!
Anyways...My passenger side fits better than me driver's ride, which is out by almso 1/2"!
BTW, in the 3rd pic, it just looks like the pic is just cut of. That's the white of my hood, blending with the screen! LOL
Attached Thumbnails ok so i take it you cant perfectly align the hatch glass on these cars right ?-p1010001.jpg   ok so i take it you cant perfectly align the hatch glass on these cars right ?-p1010002.jpg   ok so i take it you cant perfectly align the hatch glass on these cars right ?-p1010003.jpg
Old Mar 16, 2007 | 03:48 PM
Stephen's Avatar
Car: 87 GTA
My passenger side fits better...Same white thing in the 2nd pic.
Attached Thumbnails ok so i take it you cant perfectly align the hatch glass on these cars right ?-p1010004.jpg   ok so i take it you cant perfectly align the hatch glass on these cars right ?-p1010005.jpg
Old Sep 10, 2008 | 01:08 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: ok so i take it you cant perfectly align the hatch glass on these cars right ?
Stephen my trunk looks exactly like yours did in these pics, huge gap on top, did you ever fix this?
Old Sep 10, 2008 | 02:36 PM
Outlaw28's Avatar
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
stephen loosen the upper bolts and you can push the hatch upward to get it to line up..over time the struts force the hatch back like it has done on your car....you think your hatch is bad you should see mine...my car was in a wreck lol its real bad ill go take some pics and post to show yall...this is after i aligned it to the best i can without doing body work and getting parts
Old Sep 10, 2008 | 03:19 PM
Outlaw28's Avatar
Engine: 350sbc
ok i just took these pics...i need to attempt to adjust the hatch again...but only way i will get it looking as good as Randy's is if i do some body work which i need to do it possibly needs a new RH quarter panel...
heres one i took to paint an drew a line to show you where it was when i bought the car....wish i had a picture to show you...it was crazy how off it was...Randy you are very lucky to have such a nice straight hatch and car
Old Sep 10, 2008 | 06:59 PM
Stephen's Avatar
Car: 87 GTA
I haven't messed with my hatch at all.
You'd think mine was a Notchback....
"Another GTA project Lou was very familiar with was the ill-fated GTA Notchback project, finally produced for 1988. Taken on by Auto-Fab, Inc. (AFI) of Auburn Hills, MI,.... the project got off to a slow, languishing start. Apparently, AFI built the first two "prototype" decklids and then flew the parts out to the F-Car plant in Van Nuys, CA. Upon arriving and trying to fit the parts to the GTAs on the assembly line, the fit was noticeably off. GM very quickly ordered AFI to produce a second round of parts; the second time was not a charm, either as the second attempt at fitment was no better than the first.
So any time you look at a 3rdGen F-car and notice that the rear panel overlaps the taillamps just a bit.... now you know why.
The fit and alignment problems on the decklid itself were never really satisfactorily solved during the short time the option was available. If you have a Notchback, you know what I'm talking about. There is virtually no way to adjust it and get all the panel gaps in correct alignment. You pretty much have to get it as good as you can and just leave it; luckily for those of us who have these cars, most people are so taken with the design and appearance of the decklid itself that they never seem to notice the shortfalls on panel alignment."
Old Sep 11, 2008 | 12:29 PM
Car: 1992 RS 6spd
So I'm guessing you didn't fix it, and from the description I'd think mine was a notch too, but I have a camaro. So no dice there either.
Old Sep 11, 2008 | 07:39 PM
madhatter's Avatar
they aren't hard to fix but whatever you do dont use urethane sealent like the first post says he was going to use. they were put on from ythe factory with the buteryl i think its called, it is always gummy. it never hardens like urethane does. so if you use urethane and you have to for what ever reason take them apart again you will brake the hatch glass taking it apart.
Old Sep 17, 2008 | 09:51 PM
algopher's Avatar
Car: 87 Camaro SptCoupe
Engine: V6 2.8L
Hey Randy, I'm new to this site and found this thread after I had entered mine. I have a couple questions I'd like to ask you if you don't mind. My grand daughter is now driving my 87 and some work has to be done to the rear deck. My first question concerns the metal that surrounds the glass. What holds it to the glass? It has some rust on it and I'd like to take it off clean it up and repaint. Any suggestions? Did you separate the lid from the glass with the glass still attached to the car? Why originally did you take it apart? Water leaks? Thanks for your assistance in advance. I may not be able to get back to you for a while.
John
Old Sep 18, 2008 | 04:14 PM
madhatter's Avatar
John
the deck lid is held to the glass by butyl caulk/ tape however you prefer. it is a glass sealent that they used for windshields in the 60's and 70's. unlike urethane it never cures so it stays sticky all of the time. on the bottom of the decklid, there are 8 nuts to take off and a braket that the hatch shocks are affixed to. be careful. before removing make sure that you have a good prop rod holding the glass up. one the nuts and shocks are removed carefully set it back down. heat gently with a heat gun while gently wigiling it free. up and down and such. it takes a while but they do come free after about ten minutes. clean off with a razor blade. when reinstalling put butyl sealent (tape / rope caulk best way to describe it) on the glass and lower deck lid ontop lining it all up and getting straight body lines. here is the part that sucks. while you are holding it all lined up someone has to climb in and squeeze back there and put the bracket on and tighten the nuts. i haven't found or seen a better way to do this so this part of it kind of blows. you can get butyl from and body shop supply store, it is like 15 dollars for a 15 foot roll. i hope this helps need any more questions just ask.
Old Sep 19, 2008 | 08:06 AM
algopher's Avatar
Engine: V6 2.8L
I think that I'll attack the rust on the metal that surrounds the glass first and then look into separating the lid from the glass to reseal. I'm the originall owner of the Camaro, and the dealer "gooped" up an area on both sides of the uderside of the lid. I don't recall why now, but my best recollection is for water leaks. I do have some remaining "rubber" that I bought for reinstallation of the back window on my '67 Camaro that may be long enough to seal the glass to the lid on the ,87. I undoubtly will be back with more questions later. THANKS!
Old Sep 23, 2008 | 12:37 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Just dump the glass for a Notchback. Still not perfect, but a better fit and its cooler in the car. With the glass hatch in Texas during the summer months, it was like an oven in the rear seats.
JB.
Attached Thumbnails ok so i take it you cant perfectly align the hatch glass on these cars right ?-gto-005.jpg
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
TheExaminer
Aug 26, 2015 04:59 PM
BrianI
Aug 9, 2015 11:52 AM
z28addict8490
Aug 7, 2015 08:48 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
