t top seal adhesive
Old Mar 19, 2007 | 06:49 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
t top seal adhesive
starting to clean up the top rails of my t top seals, 2 cans of carb cleaner im almost done. i want to use a good adhesive when i put my new seals in, any suggestions? what have you used?
Old Mar 19, 2007 | 09:58 PM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
3M weatherstrip adhesive is what I use
Old Mar 19, 2007 | 10:34 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
i see, with a name like that i bet it speaks for itself. can you do a pair of seals with one tube, container or whatever it comes in?
well i found a 5oz tube, is that enough
Old Mar 20, 2007 | 09:02 AM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Did you remove your T-bar and clean underneath that?
Old Mar 20, 2007 | 09:46 AM
j dezzy's Avatar
Car: 87 TA
Everything looked good on my camaro until I took that t bar off. definatly check that out.
Old Mar 21, 2007 | 05:54 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Re: t top seal adhesive
yea the t top bar was the thing that started this whole dilemma in the fall,
i have a new bar and seals just waiting on the 3M glue to get here.
Old Mar 26, 2007 | 10:44 AM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
What adhesive are you going to use to secure your t-bar down? Just to share, I have used 3M's seamsealer and the it eventually dried up and water made it's way into the car again! So, this time I think I will use Permatex - Ultra Black silicone to hold the T-bar down. I have heard of a couple guys using this and they have had good results so far.
Old Mar 26, 2007 | 07:20 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
i might use the weatherstrip seal if i have any left over, if not maybe just some black silicone from home depot
Old Mar 10, 2015 | 05:57 PM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
OK then.....2015 now and men are still looking to find out what he should use. Still looking....Have we settled what was best in another thread lol.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
